8:th-Aug-2016, 11:07:01
As you can see from picture it blow off and all the thred is still in the valve cap .
up blow valve tyler |
Tyler valve blow up
8:th-Aug-2016, 17:33:41
They could just change the stem you can buy kits.
8:th-Aug-2016, 18:12:53
Hi all I had a new one fitted at a cost dam vauxhall, still have a flat tyre warning on dash tho.
8:th-Aug-2016, 19:11:27
Is the pressure showing for the valve? If not and if doesn't wake up after a drive it needs waking up with the tool.
12:th-Aug-2016, 20:08:16
I took it back to vauxhall and they did something no warning now. Pluses the did the fuel filler cap wax thing.
Fuel Shutoff Valve | NuttySqurill | 1 | 1,727 |
12:th-Aug-2020, 07:58:08 Last Post: Rusty2009 |
Cracked tyre valve with TPMS | Craig2305 | 5 | 3,801 |
5:th-Oct-2018, 13:31:48 Last Post: Craig2305 |
Dump Valve | jamoes009 | 1 | 3,411 |
17:th-Mar-2017, 23:00:19 Last Post: Wayneofwolves |
EGR VALVE, MAP SENSOR, MAF SENSOR, THROTTLE BODY NEED TO IDENTIFY | caretaker | 2 | 4,682 |
16:th-Aug-2016, 15:22:22 Last Post: caretaker |
Recirculation valve for 1.6 turbo SRI | SI SRI | 3 | 5,812 |
31:st-Jul-2014, 20:28:54 Last Post: Cameron UK |
Corsa VXR dump valve | SI SRI | 3 | 4,742 |
26:th-Jul-2014, 17:43:45 Last Post: SI SRI |
dump valve and boost guage | Dicko | 3 | 4,897 |
28:th-Jun-2014, 18:22:49 Last Post: Lush Lighting City |
Dump valve for Astra J 1.6 Turbo | SI SRI | 0 | 4,221 |
8:th-Jun-2014, 22:23:20 Last Post: SI SRI |
Cdti dump valve | richje100 | 4 | 7,573 |
8:th-May-2014, 10:43:41 Last Post: cornishtaz |
