Cdti dump valve
Hi guys, correct me if I'm wrong but does the cdti have a dump valve? I hear the whoosh sound when changing 1st, 2nd and 3rd gears and wondered if you could mod it to make it louder?
Dump valve for Astra J 1.6 Turbo
Guys need a little help. I'm after a dump valve for my 1.6 turbo. Any ideas which one or can get from?
dump valve and boost guage
Any one fitted a boost guage and dump valve to there diesels yet if so how did you fit them
Dump valve
Is there any where which sells a kit or knows how to do this to a 2.0 cdti s/s?
Corsa VXR dump valve
Does anyone know if the Corsa Vxr dump valve would fit the Astra J 1.6 turbo. I have heard that the engines are roughly the same. How true I do not know.
Recirculation valve for 1.6 turbo SRI
Guys what is the difference between a Recirculation valve and a dump valve?
Servicing the egr valve. .
. .can this be done on a 1.7 CDTI..
2.0 CDTI, EGR VALVE, MAP SENSOR AND THROTTLE BODY CLEAN
[align=center]HOW TO CLEAN THE EGR VALVE AND EGR PIPE AND MAP SENSOR AND THROTTLE BODY AND MAF SENSOR.
This How To will cover The Process of cleaning the EGR Valve
And Related Parts Needed if you are having EGR Related Problems
on the 2.0 CDTI Engine But This is also a Recommended Thing to do Every 10 or 20.000
EGR VALVE, MAP SENSOR, MAF SENSOR, THROTTLE BODY NEED TO IDENTIFY
Hi Guys,
I did have a look at Tucpal post, but i wasnt sure on mine, as it slightly different, so i have uploaded the picture to see how i can service and clean these parts.
I just wanted some information how to service my car EGR Valve, EGR Pipe, Throttle body ,  Map Manifold pressure senser.
I wanted some advice or if anyone done a 1.7cdti Elite 2011 , 61reg, as i want to do my service.
Thanks Guys.
Tyler valve blow up
As you can see from picture it blow off and all the thred is still in the valve cap .
[Image: http://i.imgur.com/FfDNALn.jpg]
