message warning airbag
Airbag Warning Message
Hi All
So as my local mechanics are hopeless and getting them to do work is like pulling teeth I thought I'd see if anyone on here knew anything about an error I'm getting.
It pops up randomly 2 to 3 times per one hour journey and sometimes stays in for 30 mins before going off. The dash says this:
The error message via OBD says this:
Anyone got any idea as to where I should begin looking? I'm guessing some loose connection or something but not sure if it's in the seat or the belt holder or what!
Ta
Check connector on seat belt presenter drivers seat if I remembered correctly it is the yellow conector under the seat
Tucpal is right, it's a yellow square connector clipped to the underside of the seat. Check its connected properly failing that the pretensioner may need replacing.... Which is £'s!
Picture from when I did mine
Ahhh yeah! Think I've seen that before! Cheers... If I'm going to unplug it and try plugging it back in again do I need to have negative off the battery?
Not sure if it was the problem but I quickly checked the cable and it seemed secure enough but the black (white in your pic @bhalay207) clip wasn't all the way in. Hoping that's all it was!
It may have wiggled loose slightly due to vibrations mate. Clear the code and see how you get on.
Yeah I cleared the code mate, checked all the connector blocks etc. And it still comes back every time I start the engine
Trying to find someone to come take a look at it but it's painfully hard!
did you not have your seat wiring wired together could be a problem there mate
unplug and take the seat out check all connectors
See I'm not sure how it was wired mate! I mean raking a look at it under the seat it all seems pretty legitimate and like factory apart from a few connectors which appear to have been soldered together but not sure how or why which is probably gonna make it hard for someone to diagnose the issue
  Check Number Plate Lamp Warning mp21 10 15,972 10:th-Nov-2020, 23:33:17
Last Post: Galway11
  ESP service message, erratic fuel range figures on trip computer mpotsb 2 6,410 7:th-Sep-2020, 12:04:29
Last Post: mpotsb
  No sound on indicators, seat belt warning and quiet front parking sensors mpotsb 4 13,841 22:nd-Feb-2020, 19:24:53
Last Post: mpotsb
  Tyre Pressure Warning Niggle phlyer 4 7,955 23:rd-Mar-2019, 11:39:36
Last Post: andyp
  Airbag light always on? Ssss 12 15,322 5:th-Oct-2017, 10:50:28
  'Service vehicle soon' message grahamfromoldham 18 75,309 26:th-Sep-2017, 10:22:30
  Fitted rear led lights, now bulb warning issues twinpipes 3 8,124 27:th-Jul-2017, 21:02:41
Last Post: Hummelshøj
  Replace steering wheel airbag newredgtc 18 18,686 18:th-Jun-2016, 06:14:26
  Tail light warning message CHTOPR 4 9,020 8:th-Apr-2015, 17:51:24
  Airbag Light sheppy1 5 11,570 5:th-Apr-2015, 10:57:04
