light message tail warning
Tail light warning message
Hello everybody.
I have changed the rear brake light bulbs to the LED bulbs philips and now every time i have a message that i need to check "stop" bulbs. Is it possible to turn off checking this "stop" bulbs?
Thanks in advance and sorry for my poor English.
I take you are asking if you can turn off the bulb checking?
If so no you can't, I'm sure you would rather know if a bulb was out rather than have a car hit you from behind?
The only way around this would be for you to install a load resistor or but the standard bulbs back in.
as rusty said the rear brake lights are on the canbus no canbus LED will cancel the errors
the only way to cancel the errors is to add a load resister between the wires
Thanks for your answers, guys.
As you have said thre are two ways to solve the problem. One way is to use a load resister and the second way is to use a standard bulb between the wires.
I thought that it is possible to disable this function by OPCOM, am I right?
Not as far as I know mate, the Op-com is still limited on the J.
  Coolant light coming on when coolant is full (new sensor and no leaks) baffling me! Brasseyebaby 3 8,098 2:nd-Feb-2021, 21:12:47
  Check Number Plate Lamp Warning mp21 10 15,992 10:th-Nov-2020, 23:33:17
Last Post: Galway11
  ESP service message, erratic fuel range figures on trip computer mpotsb 2 6,418 7:th-Sep-2020, 12:04:29
Last Post: mpotsb
  DPF REGEN LIGHT Starie 113 147,844 19:th-Apr-2020, 21:00:20
Last Post: Multiskilled
  No sound on indicators, seat belt warning and quiet front parking sensors mpotsb 4 13,852 22:nd-Feb-2020, 19:24:53
Last Post: mpotsb
Shocked Spanner Light illuminated with engine off Wwood1991 2 5,954 11:th-Feb-2020, 13:01:57
  Tyre Pressure Warning Niggle phlyer 4 7,963 23:rd-Mar-2019, 11:39:36
Last Post: andyp
  Rear Light Replacement (Need Advice) A.ROD 2 7,508 17:th-Dec-2018, 19:17:48
Last Post: A.ROD
  Help engine light Mspencer 12 17,097 18:th-Mar-2018, 17:17:36
Last Post: Mspencer
  No wiring for the interior boot light marcus01 5 9,228 20:th-Dec-2017, 16:48:23
Last Post: rlievens
