steering wheel replace airbag
Replace steering wheel airbag
Hi all.
Currently in the process of rebadging my GTC to Opel blitz from the griffin.
The steering wheel I found out however is not just a case of replacing the plastic badge, but the airbag.  Dealer want around £500 for a new one.
Was gonna just not bother (or get a sticker!), but then I found this:
http://www.ebay.co.uk/itm/Opel-Astra-J-H...SwHnFV4Zmv
Is that the right bit?  And if it is, is it just a sub one hour job for the dealer to do?
Any thoughts?
Thanks.
I would do it yourself or get a local garage to do it
save £££ on dealer labour costs
looks like the correct part but best to send them your reg or ask first just to be safe
you could look for used but you will have to look in europe ebay
thanks for reply.
I'm not against a bit of DIY - my only concern is with this particular job and the airbag exploding in my face.  Plus I want the peace of mind of knowing the airbag is fitted properly.  Good idea on another garage though - will make some enquiries.  Bound to be cheaper than the dealer.
Looks like the right part to me.
Have a look at my thread and it will guide you through doing the job yourself.
https://www.vxoc.org.uk/forum/Thread-How...el-Buttons
Thanks Rusty.
Actually I'd seen your guide and it was that that scared me off a bit!
But I've just had another careful look and actually, if i've understood it right, being as i'm just removing the airbag and not the whole wheel or buttons, all I have to do is the turning the wheel upside down bit, the two holes in the back, pull the airbag away, and disconnect one wire - is that correct?
One other thing - there won't be any electronic issues will there - computer sensing that an airbag has been tampered with or something like that?
Thanks again.
No there shouldn't be any problems atall.
Just pull the negative off the battery and let the systems discharge before hand.
Its a 5 to 10min job real easy as said above just disconnect the battery negative
(10:th-Jun-2016, 01:30:41)newredgtc Wrote: my only concern is with this particular job and the airbag exploding in my face.
I deal with accident damage cars, I've had the odd airbag go off, I can assure you it is not a nice experience at all.
Well.. I've had the airbag portion out and even broke a clip that connects the cable to the air bag and all was fine with me... I never had the front cover with the badge off though
i was just all nice and confident and reassured by the other comments, then you come along and make me scared again! lol
lol in all seriousness thanks for the warning though. I've just bought the part now, so I'm gonna give it a good go and just take my time and be careful. I might wear a motorcycle helmet as I do it ;-)
Neighbours will think you've lost the plot haha
HAHA just remember to follow the instructions
I've removed my airbag a handful of times on the Astra and many times before on previous cars and not once have I had one go off. Take the negative battery off and leave it for 15 or so mins for the car to discharge and then get it removed. You'll be fine!
You've no need to worry if you follow all the instructions, look in the general chat area of the forum you'll see a couple of photos of stuff I pick up, they've usually gone off if it's front end damage and I ram it onto my lorry (when driveable), not very often with modern cars but older ones are more prone to it
So do you literally find written off cars left at the side of the road and take them?! Ha
reporting back in!
I did it! Lost heart after about 20 minutes of trying to slide the metal bars across - the one side just wouldn't come loose no matter how hard i pushed - my fingers and thumbs are killing me now and i bent two screwdrivers!
Anyway I kind of got the knack of it in the end and once it was off, whole job was complete by about two mins later. Computer did ask me to wind down and then back up my windows which i guess is normal but apart from that, everything's perfect!
Only a simple job in the grand scheme of things I know, but pretty chuffed I did it myself lol
I like the improved look!
https://goo.gl/photos/HHmW5N3CVpacMoDv5
Haha some are at the side of the road, alot at recovery garages/car bodyshops, unless i can see it's mullered i'll always try to drive it on, beats trying to get my lorry in and using the winch, had one bmw, front wheel smashed completely off, doors on one side and the roof cut off, still started and drove it onto my lorry, thank god for RWD
The window thing is just to reset the auto open close setting.
Quickest way to reset it is just to hold each switch up rather than taking them all down and then all up.
WELL DONE
  Steering wheel angle, esp, power Steering smoky-jr 3 7,426 6:th-Jun-2021, 18:23:26
  Broken wheel stud Euroshopper 1 3,724 6:th-Oct-2020, 07:08:18
  Replace windscreen washer bottle cap ma444 1 4,683 4:th-Oct-2020, 07:51:42
  Steering wheel from Astra K foxydimsi 2 6,860 1:st-Oct-2020, 06:49:56
  GTC limited edition alloy wheel paint code Nathan191210 5 7,304 1:st-Aug-2020, 19:22:43
  2017 GTC Limited edition - Front wheel noise Nathan191210 4 6,586 12:th-Jul-2020, 07:37:10
  space saver wheel Gary13 5 7,251 24:th-May-2020, 19:02:57
Last Post: Gary13
  Squeak when turning steering wheel Rusty2009 12 25,437 12:th-Sep-2019, 21:45:35
Last Post: Boycey1969
  Lowering and wheel spacers twinpipes 1 4,352 28:th-Jul-2019, 08:43:33
  Astra VXR heated steering wheel THEHITMAN 26 28,380 10:th-Mar-2019, 09:34:44
