Steering wheel airbag removal
Has anyone removed the the airbag / horn from the steering wheel?
Had a look on the workshop manual and it says to make a tool to unhook it form the back.
I know to disconnect the battery and wait at least 30 minutes.
How-to Remove Airbag Steering Wheel & Buttons
sheppy1 - Replies:
Airbag Light
Okay, just had something brought to my attention about the airbag light which would normally be on the dashboard next to where the hazard button is. I'm sure that I used to have a light which lit up and showed something about the airbag being enabled...Vauxhall also said that I should be seeing one...but it's not lit up now and i'm sure it used to be...Does anyone know what I mean and also know if it should or shouldn't be lit up...?
Replace steering wheel airbag
Hi all.
Currently in the process of rebadging my GTC to Opel blitz from the griffin.
The steering wheel I found out however is not just a case of replacing the plastic badge, but the airbag. Dealer want around £500 for a new one.
Was gonna just not bother (or get a sticker!), but then I found this:
http://www.ebay.co.uk/itm/Opel-Astra-J-H...SwHnFV4Zmv
sheppy1 - Replies:
Airbag Warning Message
Hi All
So as my local mechanics are hopeless and getting them to do work is like pulling teeth I thought I'd see if anyone on here knew anything about an error I'm getting.
It pops up randomly 2 to 3 times per one hour journey and sometimes stays in for 30 mins before going off. The dash says this:
[Image:
http://uploads.tapatalk-cdn.com/20160925...d2a582.jpg ]
The error message via OBD says this:
[IMG]http://uploads.tapatalk-cdn.com/20160925/e68d66bd3b103ec5f2ba6
DNT - Replies:
How-to disassemble airbag
[Image:
[align=center]I decided to make this how-to in case someone wants to change steering wheel badge or replace it with a new one if damaged. You don't have to buy a new airbag, you just need to replace the front plastic cover. Swapped covers a month ago and it is a pretty easy job. The hardest part is to source the plastic cover.
Ok, first remove airbag. For removing airbag see here: [url=https://www.vxoc.org.uk/foru
Ssss - Replies:
Airbag light always on?
Hi, im new here and need some help please...
Today signed up for a 1.4sri GTC 2014 which is lovely however while test driving i noticed the airbag ON light in the center console was lite up all the time. I asked the sales chap if this was normal and he suggested it was fine. However im not so certain so wanted to check with people that may know. Please can you let me know your thoughts on this before i make full payment. Cheers!
Airbag connector
Hi all
This is my first post, all i did so far was reading
My english is not so good but i'll do my best.
I have a tiny problem on my astra, and i could use some help from you guys.
I tried to swap my steering wheel with leather one from insignia (found one at scrapyard)
All went well, until i tried to fit my airbag inside. Turns out it does not fit. So i go back where i bought the steering wheel and i buy the airbag too.
That was stupid act from my side (i gave 70 euros for t
