with sensor not pressure glowplugs or
Glowplugs with pressure sensor or not
Hello,
I have a Astra J 1.3 CDTI with engine code: A13DTE
I need to change my glow plugs. How do I find out if my car uses those expensive glow plugs with sensors or not?
Kind regards
Euro
To be sure if you pm me your reg I'll get you the part number
You might find you have a combination of both types, depending on which cylinder the troublesome one(s) is.
i.e. not all the cylinders might have the sensor plugs.
It has 2 sensor ones and 2 standard ones as it's a 2010
Standard 55564219 cylinder 2 & 3
Sensor 55577419 cylinder 1 & 4
  Clean DPF - O2 sensor location Henhead78 1 131 24:th-Apr-2026, 17:31:05
  Brake pedal sensor learn. Richiew1986 0 3,016 22:nd-Jul-2021, 16:53:31
Last Post: Richiew1986
  coolant pressure tester chuzzle359 0 3,400 14:th-Apr-2021, 18:23:08
Last Post: chuzzle359
  parking sensor Qaranc 1 3,886 8:th-Feb-2021, 01:33:43
Last Post: loeb
  Coolant light coming on when coolant is full (new sensor and no leaks) baffling me! Brasseyebaby 3 8,132 2:nd-Feb-2021, 21:12:47
  Easy removal of glowplugs? Euroshopper 1 5,542 13:th-Nov-2020, 16:21:11
Last Post: eatmybogbrush
  DPF pressure sensor richardhmorgan1 3 7,012 24:th-Sep-2019, 20:08:31
Last Post: Saunter
  Tyre Pressure Warning Niggle phlyer 4 7,983 23:rd-Mar-2019, 11:39:36
Last Post: andyp
  Parking sensor Mspencer 2 5,124 19:th-Dec-2017, 17:34:12
  A/C pressure sensor location scotchmist67 0 4,334 2:nd-Aug-2017, 10:04:34
Last Post: scotchmist67
