removal easy of glowplugs?
Easy removal of glowplugs?
One of my glow plugs is defect, so they need to be changed. I have a A13DTE engine and there is a step by step guide here on how to change them: https://www.youtube.com/watch?v=onMmIltMokQ&t=637s
However this is quit intricate process by removing turbo and DSP, one or two comments on this video claims that all glow plugs can be removed by using a glow plug removal socket set and only removing the oil feeder and heatshield.
Like this: https://www.ebay.co.uk/itm/282975441040
Have someone done this before and can confirm this is possible? Would be way easier to just buy such a set and remove them without to much trouble.
Cheers!
Looking at the video you only need a normal deep 10mm socket which is what I used on my Astra H 1.9, plugs look the same and I had no trouble, don't tighten them like the idiot on that video way too tight, they only need to be done gently, really to a specified torque.
I used a £5.72 Draper expert Hitorq 10mm deep socket here
https://www.ebay.co.uk/itm/Draper-Expert...Swm1NfpTZj
  Glowplugs with pressure sensor or not Euroshopper 3 5,460 2:nd-Nov-2020, 16:01:21
  Small glove box removal chrisb2511 7 10,729 5:th-Mar-2019, 13:14:03
  Best Dashcam and easy to install caretaker 5 8,234 30:th-Jul-2018, 18:49:11
  Astra J 2.0cdti engine removal Iaintruten 0 5,480 2:nd-Nov-2017, 16:23:36
Last Post: Iaintruten
  New rear dics and pads fitted nice easy job![emoji16] Force1378 0 6,118 8:th-Dec-2016, 20:12:40
Last Post: Force1378
  dpf removal and remap on a17dte? rbull51 4 8,277 1:st-Dec-2016, 23:02:47
  Drivers door glass removal Daz21 3 6,851 19:th-Aug-2016, 17:11:38
  Indicator / fog light removal Scoobysn7x 3 6,509 20:th-Jul-2016, 16:52:17
  Front griffin removal cornishtaz 1 5,136 6:th-Apr-2015, 21:38:02
  Rear Griffin Emblem Removal TUFFKNUX 13 18,151 5:th-Apr-2015, 22:54:14
Last Post: SI SRI
