removal j astra 0cdti engine 2
Astra J 2.0cdti engine removal
Hi was wondering if anyone has had the engine out the astra as long story short I need a new clutch and water pump but I know it is a sub frame off job for gearbox removal but was thinking of just lifting out the engine and doing the clutch and timing belt and water pump etc that way. Was just to see if anyone has managed to lift it out without removing the sub frame and gearbox.
  VAUXHALL ASTRA 1.7 CDTI FUEL SENDER UNIT 13272601- FUEL ERRATIC GUAGE BELWO HALF TAN caretaker 3 4,721 21:st-Oct-2024, 18:22:15
  1.4T Engine noise Nathan191210 1 3,886 29:th-Jun-2021, 09:05:07
Last Post: jay2801
  Vxr bumper on 5 door Astra j Sh4rk2007 10 15,102 6:th-Jun-2021, 18:25:04
  New Battery for Astra J 2013 reg 1.7 diesel Galway11 6 8,984 13:th-May-2021, 11:38:55
  Astra j gtc modifications BillyBryan 2 5,529 9:th-May-2021, 17:15:36
Last Post: Spaghetti
  Please advise - Z16LET engine (1.6 turbo, 132 kW) - is it a direct or indirect port? UseThe4s 2 8,348 18:th-Apr-2021, 09:58:47
Last Post: UseThe4s
  Astra J Fault code reader suggestions Euroshopper 1 5,372 22:nd-Feb-2021, 08:50:12
  Astra j bonnet won't open help Paul in sheppy 2 5,471 17:th-Feb-2021, 13:13:46
Last Post: Paul in sheppy
