removal box glove small
Small glove box removal
Does anyone know how to get small glove box under steering wheel off? Im putting a pedal box on and wanted to feed it up through the small glove box/cubby hole. Somebody said it just pulls off but i cant get it out
Good idea... That's what I've done too. And all you need to do is open it like you normally would and then you sort of squeeze the sides of the box together and it will allow it to drop down further and be removed
(18:th-Aug-2016, 15:52:51)sheppy1 Wrote: Good idea... That's what I've done too. And all you need to do is open it like you normally would and then you sort of squeeze the sides of the box together and it will allow it to drop down further and be removed
Just squeeze the inside bit? Ill give that a go. Not sure where else to put the controller other than in there
That's the best place for it yeah... Basically just the two plastic sides that make up the walls of the compartment... I think it may just he one of them you have to squeeze actually... Basically need pulling ever so slightly inwards and then it let's the whole thing drop down
Yea I've done the same thing with my pedal box, you open the door and pull both sides inwards to release it
All done and dusted thanks fellas
(18:th-Aug-2016, 15:17:49)chrisb2511 Wrote: Does anyone know how to get small glove box under steering wheel off? Im putting a pedal box on and wanted to feed it up through the small glove box/cubby hole. Somebody said it just pulls off but i cant get it out
Hey yes, I have tried pushing and pulling and squeezing with no avail.  I have purchased a replacement which has open ended hooks on the bootom which looks as if they just push onto a bar.  But cannot get the old one off and don't want to break it.  The reason for replacement is the spring on the catch has gone and the box just remains open and is awkward getting in and out of the car..  Any advice would be gratefully received for my 63 plate astra J.
When you open the pocket you need to pull the right side wall to the right and it'll come out then pull off from the bottom.
  Easy removal of glowplugs? Euroshopper 1 5,552 13:th-Nov-2020, 16:21:11
Last Post: eatmybogbrush
  Astra J 2.0cdti engine removal Iaintruten 0 5,715 2:nd-Nov-2017, 16:23:36
Last Post: Iaintruten
  dpf removal and remap on a17dte? rbull51 4 8,718 1:st-Dec-2016, 23:02:47
  Glove box bulb JPW 2 6,389 25:th-Oct-2016, 19:02:58
Last Post: JPW
  Drivers door glass removal Daz21 3 7,188 19:th-Aug-2016, 17:11:38
  Indicator / fog light removal Scoobysn7x 3 6,783 20:th-Jul-2016, 16:52:17
  Small things which bug me bhalay207 34 27,691 8:th-Oct-2015, 07:27:07
Last Post: bhalay207
  Front griffin removal cornishtaz 1 5,322 6:th-Apr-2015, 21:38:02
  Rear Griffin Emblem Removal TUFFKNUX 13 18,942 5:th-Apr-2015, 22:54:14
Last Post: SI SRI
  Vent Removal/Checking sheppy1 8 14,240 6:th-Mar-2015, 18:20:22
