removal vent checking
Vent Removal/Checking
Not sure if this belongs here at the moment...not unless someone has enough info to turn it into a how too anyway...but I need help regarding the two air vents in either side of the car near the doors. These are the ones that have the silver trim on them.
Basically I've managed to make mine very loose due to replacing the trim on them and was wondering how I'd go about tightening them up...this does sort of lead on to a how too for removing them completely and how to put them back in again I guess as I notice we don't have one for that.
Not quite sure how they come out not looked TBH.
Awwww no! I thought there would be a cheeky how to lying around somewhere that i'd missed lol
This is what the Haynes says
Air Vents
Removal
1 To remove the vents from each side of the fascia, carefully prise free the relevant vent using a plastic spatula or similar tool to depress the four retainers.
2 To remove the air vents from the centre of the fascia, remove the fascia upper centre panel (radio fascia).
3 Depress the four retainers securing each vent and withdraw the relevant vent from the fascia.
Refitting
4 Refitting is a reversal of removal.
They give no pictures so if you want to do a How-to please do.
Thanks for that rusty! that's for the centre console ones though..I was referring to the ones nearest the doors
this is the door ones
the rest is for the centre vents
moved to retro fit research till you get a how to done
look at these pictures you will see the tabs marked with a white arrow
there will be 4 tabs i would say if they are loose then they just need a bang back in place
as for how they come out or you get to the tabs not to sure
Hahaha the good old "give it a whack" solution eh :P. Thanks for that, I wasn't looking to actually remove them so probably won't be able to help turn this into a how to. I just wanted to know how they did come out so that I could figure out if they are broke or just loose.
Thanks for that
Rusty2009 Wrote:this is the door ones
Ahhhh yeah! I get ya now, that lines up with what tucpal was saying awesome...cheers
  Easy removal of glowplugs? Euroshopper 1 5,538 13:th-Nov-2020, 16:21:11
Last Post: eatmybogbrush
  Small glove box removal chrisb2511 7 11,181 5:th-Mar-2019, 13:14:03
  Astra J 2.0cdti engine removal Iaintruten 0 5,684 2:nd-Nov-2017, 16:23:36
Last Post: Iaintruten
  dpf removal and remap on a17dte? rbull51 4 8,664 1:st-Dec-2016, 23:02:47
  Drivers door glass removal Daz21 3 7,141 19:th-Aug-2016, 17:11:38
  Indicator / fog light removal Scoobysn7x 3 6,761 20:th-Jul-2016, 16:52:17
  Front griffin removal cornishtaz 1 5,303 6:th-Apr-2015, 21:38:02
  Rear Griffin Emblem Removal TUFFKNUX 13 18,775 5:th-Apr-2015, 22:54:14
Last Post: SI SRI
  Steering wheel airbag removal Rusty2009 5 11,752 17:th-Jun-2014, 09:20:32
