Howto remove glove box & Replace Pollen Cabin filter
How to Remove and Replace the Cabin Pollen Filter
for the Astra j and GTC.
STEP ONE.....
Pull out the Door Seal just by the side of the Glove Box
to gain Access to the side Trim so it can be Removed.
[Image: http://www.vxoc.org.uk/Images/tucpal/How...ebox/1.jpg]
Just Pull the side Trim away
to Gain Access to the 4 Bolts.
[img]http:
HOW TO: Replace Glove Box Bulb Without Removing Glovebox
So i thought id show you guys how to change the glove box bulb for a nice w5w 501 smd bulb, i used one with 12 smds.
Items needed:
Blunt knife of plastic lever
New bulb
So this firstly, how the light switch works, when the pin is extended the light comes on, when the pin is pushed in, the light goes off.
The first step is to use a blunt table knife or other tool to lift down the light from the rear a
FREE: LEDs for Boot/Glove Box
Don't suppose anyone wants a free pack of these bulbs do they? I bought a bunch of them as I was going to use them for the interior lights but they are too big...so can only be used for the boot light and glove box light. I used a few but have some left.
Photo is attached for reference.
[ATTACH]505[/ATTACH]
How to hardwire 2 x USB ports into the glove box for dashcam/phone
Afternoon all
As I promised in my welcome thread, thought I would provide a tutorial for adding two powered USB ports in the glove box for powering my dashcam and charging my phone.
Remove Glovebox You will need to do this so follow these instructions.
The kit list I used for this is below
1 x USB Adapter from Ebay (Link to Item)
1 x Pa
Small glove box removal
Does anyone know how to get small glove box under steering wheel off? Im putting a pedal box on and wanted to feed it up through the small glove box/cubby hole. Somebody said it just pulls off but i cant get it out
Glove box bulb
2012 gtc 2.0 cdti Sri
Hi all, my glove box bulb stopped working last night and I've replaced the bulb but still isn't working...... does it share the fuse with something else as everything seems to be working fine ...... if someone could point me in the right direction as too which fuse box to look in that would be great
Cheers james
