Howto remove glove box & Replace Pollen Cabin filter
How to Remove and Replace the Cabin Pollen Filter
for the Astra j and GTC.
STEP ONE.....
Pull out the Door Seal just by the side of the Glove Box
to gain Access to the side Trim so it can be Removed.
[Image: http://www.vxoc.org.uk/Images/tucpal/How...ebox/1.jpg]
Just Pull the side Trim away
to Gain Access to the 4 Bolts.
[img]http:
gear box issues
gear box issues
Got one or had one post here
i think we all know the M32 will be popular in this section.
HOW TO: Replace Glove Box Bulb Without Removing Glovebox
So i thought id show you guys how to change the glove box bulb for a nice w5w 501 smd bulb, i used one with 12 smds.
Items needed:
Blunt knife of plastic lever
New bulb
So this firstly, how the light switch works, when the pin is extended the light comes on, when the pin is pushed in, the light goes off.
The first step is to use a blunt table knife or other tool to lift down the light from the rear a
2.0 CDTI Stop/Start and the DTUK RED BOX
Vauxhall have issued an update for the ECU for all 2.0 CDTI 160/165Ps with Stop/Start.
There has been reports that this is stopping the DTUK RED BOX working correctly, DTUK are aware of this and have worked on a fix for it although the fix might not work for all at this time.
I emailed DTUK this morning to find out where I stand as I already own the box I was told
[quote]You'll just have to wait and see what happens once the car is serviced in September as there is no pattern. Some cars are a
How-to Adjust Gear Linkage F40 Box
[align=center]How-to Adjust Gear linkage
Please note this is on a F40 box
1, Remove the mat, storage tray & gear gator.
[Image: https://www.vxoc.org.uk/Images/rusty/pos...kage/1.JPG]
[Image: https://www.vxoc.org.uk/Images/rusty/pos...kage/2.JPG]
[Image: https://www.vxoc.org.uk/Images/rusty/pos...kage/3.JPG]
2, Then you need to release the gear linkage there are two b
Gear box oil, to change or not to change?
So your thinking of changing your gear box oil? Well... So was I. I wanted to know if there are any NOTICABLE benefits, only takes about 15 mins and will cost £25 for 2L(you need 1.5L for the 2.0 diesel but can only buy in 1L). Will do a how to later this evening but this thread is to chat about it. What's your opinions?
HOW TO: Replace Gear box oil
HOW TO CHANGE THE GEAR OIL...
Changing your gear box oil is thought to be not necessary but i found it to improve smoothness of gear changes especially as i was having some issues changing from 1-2 and 2-3. The part number for my oil was which i got from my local dealership. If you need to know your oil number then contact rusty. I measured how much came about and it was about 1.
dtuk box aftre softwhere update
Any one had any problems after software updates
Mine seams down on power
But drives ok
DTUK Red Box
Hi, Does anybody know anyone that drives a Astra H Diesel that might be interested in buying a DTUK Red Box
At the moment ist programed for 2.0cdti Astra J, but for free Dtuk will swap it to work on any car that the Red Box works on.
Any help will be appreciated.
Pedal box VXR
