check door strap replacing
Replacing door check strap
My driver's door makes a loud clonk when I open it and I've been told the check strap needs replacing.  Is this an easy job?  I can only find guides for other models where the door card has to come off, is that needed for the Astra?
Yes the door card needs to come off then remove speaker.
OK thanks I'll check out your how-to guide.
replaced mine with front ones from a astra k, lot thicker plastic
(4:th-Feb-2019, 19:19:31)paddydel Wrote: replaced mine with front ones from a astra k, lot thicker plastic
Is that a straightforward replacement?
I also have a question; can I use Astra J or K check straps on my GTC or are they specific?
  Vxr bumper on 5 door Astra j Sh4rk2007 10 8,090 6:th-Jun-2021, 18:25:04
Last Post: jeniferbitcoin71
  Diesel door wont opel Arkanggel10 2 1,468 13:th-May-2021, 15:31:33
Last Post: Arkanggel10
  Check Number Plate Lamp Warning mp21 10 8,462 10:th-Nov-2020, 23:33:17
Last Post: Galway11
  door drain grommets bigbadkes 2 2,081 28:th-Aug-2020, 19:45:49
  1.6 cdti 5 door exhaust tip? h4r7y 1 2,126 17:th-Jul-2020, 06:47:38
  passenger door deadlocked celrx 3 2,052 15:th-May-2020, 15:29:46
Last Post: paula9568
  Door locking Flick19191 1 1,851 22:nd-Nov-2019, 09:40:18
  Lacking Power - What can I check everson38 3 2,864 10:th-Jul-2019, 10:44:50
  Astra J 5 door facelift bumpers Iaintruten 5 4,279 30:th-Oct-2017, 16:40:35
Last Post: Iaintruten
  5 door drl to led rfoster88 3 3,846 3:rd-Oct-2017, 16:58:03
Last Post: rfoster88
MrDjArMz (16:th-May-2023, 13:08:56)
