6 door tip? cdti exhaust 1 5
1.6 cdti 5 door exhaust tip?
I wonder if anyone else has wanted a visible exhaust tip for their 1.6cdti 5 door? On the 2.0 cdti you can see the exhaust under the rear bumpers valance, does anyone know if its easy to swap over from the 2 litre car? Or could i just buy the bumper insert and a backbox after that? (Im led to believe theres little point in getting anything performance related for a diesel exhaust?)
Thanks in advance!
If you know the size of your pipe here are the sizes of the 2.0cdti pipe into the backbox is 55mm & from backbox to tail pipe it's 65mm.
  Astra 1.6 CDTi Turbo Issues P2598 shaky411 1 2,528 12:th-Sep-2021, 15:24:05
  2.0 CDTi Auto Gearbox Oil Change Dennis S 0 1,526 13:th-Aug-2021, 14:29:25
Last Post: Dennis S
  Vxr bumper on 5 door Astra j Sh4rk2007 10 8,047 6:th-Jun-2021, 18:25:04
Last Post: jeniferbitcoin71
  Diesel door wont opel Arkanggel10 2 1,455 13:th-May-2021, 15:31:33
Last Post: Arkanggel10
  Astra J 1.4T Exhaust help sammpennington 1 3,794 12:th-May-2021, 14:29:50
Last Post: azajus
  GTC exhaust options johno1412 1 3,056 12:th-May-2021, 14:26:49
Last Post: azajus
  Astra J GTC 2.0 CDTI A20 DTH Stage 1 Remap - Wayside Performance M222RJF 8 4,659 11:th-Sep-2020, 20:55:21
Last Post: badger64
Astra 1.7 CDTI fuel quality problem klajdi 0 2,034 10:th-Sep-2020, 12:10:05
Last Post: klajdi
  door drain grommets bigbadkes 2 2,067 28:th-Aug-2020, 19:45:49
  1.6 cdti engine reliability Loddy Jeff 7 8,807 9:th-Jul-2020, 22:04:47
Last Post: Loddy Jeff
