Replacing Aerial
Hi, I have seen a couple of pictures showing some of the headlining being pulled down from around the tailgate for aerial removal. How far do you need to go to get the aerial out as I pulled along the whole of the tailgate edge and it was still too tight to gain propper access or even see the aerial base nut. The FM aerial connector seemed to be fixed to the roof somehow, so it looks as though I will have to remove quite a bit of the roof lining, unless I am missing something?
I just don't w
Replacing door check strap
My driver's door makes a loud clonk when I open it and I've been told the check strap needs replacing.  Is this an easy job?  I can only find guides for other models where the door card has to come off, is that needed for the Astra?
Astra J. Can a tyre valve be replaced without replacing the TPMS?
I have an Astra J hatchback, 2015 reg, I think it is “pre facelift” but not sure.
It has slow punctures on both off side wheels
My tyre garage (Formula 1 Autos) told me that air is leaking from between the valve body and the alloy wheel seat.
They say that if I can get hold of replacement valves they will replace them. They say that this will not involve disturbing the TPMS.
Are they correct?
Is the TPMS separate from the valve on this car? All I can find are combined TPMS and valve
P0128 2 weeks after replacing temp sensor
I have a 14-plate 1.6 Astra Auto.
Recently got the "AC Off Due To High Engine Temp" warning, and an OBD II dongle said it was a P0128.  At the same time the temp gauge went to minimum.  Checked under the bonnet and the fan wasn't running even though we watched the coolant temp run up past 90C.
I'm no mechanic, but my local independent garage swapped out the engine temp sensor, topped up the coolant, cleared down the error code, and everything was back to normal.  Indeed after driving
