issue seat heated elite
elite heated seat issue
hi i am looking into getting an astra elite and i am finding that there are no elites so far without the heated seat issues. is it worth keep looking for a car without the heated seat issue or find one i like and solve the issue later
Hi Give up looking if did find one then it would soon be an issue.
In terms of fixing the fix never lasts long 6-12month then its back again.
thanks for the info rusty i will take that off my check list.
What is the issue?
I have a 2013 Elite (63 reg) with heated leather, and both seats work ok with regard to heating up.
Probably tempted fait now though.
(29:th-Jan-2019, 12:24:29)Big Dave2 Wrote: What is the issue?
On almost all Drivers seats the seat will turn off after a couple mins very common fault.
I think your find if your seat stays in one position and is very hardly moved your be ok.
So from what I can gather from my research you need to replace the connector to the upgraded version and the heat pad itself yet this repair is only likely to last about 1 year!!!?
The connect is the first thing to try. if that doesn't do it it's a new heatpad.
Nope, not noticed this with mine (or the passenger seat). Had the car 4 years now. Seat rarely gets moved, other than to vacuum under it from time to time.
  DRL - sidelamp issue stajerad 1 4,338 12:th-Sep-2021, 15:37:54
  VXR Seat (not the handle) Bigsmokeuk 1 4,335 12:th-Feb-2021, 11:16:57
Last Post: killboy
  DRL/Sidelight Issue MassiveRoy 1 4,072 10:th-Feb-2021, 19:57:52
Last Post: Rhun91
  A slightly different seat tilt breakage killboy 1 5,285 28:th-Jan-2021, 23:20:12
  Astra J Rear Bench Seat Clip. MrScottyMan 1 7,138 24:th-Jan-2021, 14:44:22
  2 days and already an issue..... MrCrunchy 6 7,062 18:th-Sep-2020, 18:32:29
Last Post: MrCrunchy
  Drivers seat broken trim Big Dave2 10 9,975 21:st-Aug-2020, 22:19:41
  Aftermarket android H5754 headunit issue simpledun 1 4,958 4:th-Jun-2020, 09:17:15
  No sound on indicators, seat belt warning and quiet front parking sensors mpotsb 4 13,839 22:nd-Feb-2020, 19:24:53
Last Post: mpotsb
  ASTRA J HEADUNIT ISSUE AstraJ_OwnerSK 1 4,611 10:th-Nov-2019, 08:31:13
