Bi-turbo seat look
My son and I have both decide to colour the seats the same as the bi-turbo,
have thought of doing it myself but don't really want to muck it up.
Where would I go for this a seat restorer or something and any idea on price?
Drivers Heated seat turning off
Had this on my Elite it ended up having the pad replaced. When switched on they would work for about 2 minutes and then turn off. However if you put them on a lower heat setting they would stay on longer.
Anyway the VXR has started this morning. Heated seat works for 30 seconds no matter which heat setting you have it on. I've seen some people mention that there is a bulletin regarding the wiring loom when they have had the same issue. Does anyone know if this the case or not?
rear seat belts
Well after cleaning the inside of the car today i discovered
that you can store the rear seat belt out the way and stop it knocking against the plastic trim
[Image: http://i179.photobucket.com/albums/w301/...e7ac59.jpg]
[Image: http://i179.photobucket.com/albums/w301/...099c0e.jpg]
[Image: http://i179.photobucket.com/albums/w301/...a8c50b.jpg]
it sits in there nice and snug
and it only took me two and a half years to fi
Rear seat belt buckle
I'm going to retrofit the rear seat belt buckle with sensors,
I've ordered both the buckles cost £29.00 posted as opposed to £110+.
I have the wiring diagram just can't seem to locate the terminals for it so if anyone can help that would be good, even if you know what other Vauxhall car it's fitted and where it is I can go up the scrappy and get one.
[Image: http://vxoc.org.uk/Images/rusty/K36.bmp]
Connector Part Information
Harness Type: Body
OEM Connector: 19151247
Service Connector: 1
Astra j seat heating controls [SOLD]
Heated seat module
Hi, I'm after a heater control panel with the heated seat function (without climate control) is anyone has 1 up for grabs please pm me
Leather Seat Types Elite
Are all leather seats from elites heated with electric lumbar control? Basically i was going to buy some from someone on Gumtree and he said they were all electric and couldn't be controlled manually and were heated too. I ended up with some on eBay thought but the guy on there didn't know if they were heated or not and also said that they could be controlled manually and electronically (the movement that is) so just wondering if both sets were actually the same but each person didn't know every
Seat Connector Swap
Hi Guys
So it turns out the guy who sold me the elite seats was an idiot and cut the connectors off the bottom of the passenger seat!!! The garage are going to try and take the connectors from my old seat and splice them into the new seat...is that safe to do though and would the airbags work fine?
Rear Seat Clips
Hi Guys,
So the cowboy who fitted my seats appears to have not done the back one properly and/or broke the clip while doing it. Basically the back seat isn't clipped into the actual base properly so I can lift it up really easily. From feeling around it feels like one of the metal prongs which is covered with a black plastic clip isn't actually clipping into the base properly...it actually feels like the black plastic clip is broken.
Does anyone know where i can get another one of these f
HOW TO FIX HEATED SEAT AND REPLACE SEAT COVER ASTRA J
HOW TO FIX HEATED SEAT PROBLEMS AND REPLACE THE SEAT COVER.
This How to will Cover How to Fix the Heated Seat from Intermittently Dropping out and Cutting off
This is a Big Job but Easy when you know How.
The main Problem is a Bad Connector to the Seat Heating Control Module
[align=center]This over Time wil
