GENERAL AND THINGS TO CHECK.......
This How to is for the Heated Leather Seats
And Electric Lumber Support on the Astra J 5 Door
I have been Told this will Work for the GTC as well.
The first Thing you are Going to do is to Check the Rear Fuse Box
in the Rear Boot and look for a Fuse in Position (21)
a (25 amp) Fuse should be There if so you
Heated washer jets
Just browsing EBay and came across these
Says they will fit the j
Says a 12v ignition feed I know there was a problem with these on the insignia I think it was (catch fire) so was thinking a switch could be used so they are only on when you need them on.
Drivers Heated seat turning off
Had this on my Elite it ended up having the pad replaced. When switched on they would work for about 2 minutes and then turn off. However if you put them on a lower heat setting they would stay on longer.
Anyway the VXR has started this morning. Heated seat works for 30 seconds no matter which heat setting you have it on. I've seen some people mention that there is a bulletin regarding the wiring loom when they have had the same issue. Does anyone know if this the case or not?
Heated Seats Description and Operation
Heated Seat Components
The driver and passenger heated seats consist of the following components:
• Left heated seat switch
• Right heated seat switch
• HVAC control
[align=center]• Seat heating
Heated Steering Wheel
Did the J ever come with the heated steering wheel option in the UK?
If not, you got to wonder why. I've seen a load of Corsa D's with the SE trim coming through the workshop that have them.
Who knows, maybe the higher up J's have them fitted, but just need the button fitted! Wishfull thinking
Anyone got the option?
Astra VXR heated steering wheel
Hi guys, I have a chance of a VXR heated steering wheel off a 2014 Astra which I'm looking to install in my 2011 Astra 1.7 Elite.
Now unfortunately the airbag is missing so does anyone know if I can simply swap the airbag from my Elite into the VXR steering wheel?
Also can the heated part of the steering wheel be connected to work?
Thanks in advance.
Heated seat module
Hi, I'm after a heater control panel with the heated seat function (without climate control) is anyone has 1 up for grabs please pm me
12-VOLT HEATED ICE & SNOW SCRAPER
have to say this is the best thing i have ever seen on ebay
http://www.ebay.co.uk/itm/12-VOLT-HEATED...3f404c9192
Heated Seats Pin Out's & Schematics
Heated Seats Schematics
[Image: http://www.vxoc.org.uk/Images/vxoc%20ast...matics.jpg]
X310 Body Harness to Drivers seat Pin Out
[img]http://www.vxoc.org.uk/Images/vxoc%20astra-j-gtc/Tech%20data/Heated%20Seats/Pin%20out%27s%20Schematics
Heated Wing Mirrors
Been wondering about this for a while but how exactly do the heated wing mirrors work? I've noticed that sometimes they come on but other times they don't...yet I'm not sure what action is required to make them come on...Does anyone know?
