works with light but headlights again out rear
Rear light out but works again with headlights
Hi, I have a astra gtc biturbo with standard rear lights. With the drls on the left side rear had the bulb working but the offside rear is off. If I switch the headlights on then both bulbs work as they should. Anything causing the rear not to work? On the front I have led drls and installed a hid kit for the headlights all of which work well..
On the 5-door when DRL's are on it's only DRL's that are on no rear lights on at all, I would of thought it should be the same for the GTC.
My DRL's are the only lights on when driving daylight conditions, my rear lights turn on when the auto lights settings kick in or alternatively if I manually turn on the lights, can't imagine any difference in the wiring set up, mine's on a 14 plate with LED rear lights.
Well from your replies sounds like 1 bulb is getting power sent to it, v strange. I wonder if the front set up has anything to do with it then.... Maybe due to the drls on the front being led and using less power...
As said above, usually only the front drls come on, no rear lights
the normal drl bulbs are twin filament (one for drl, one for sidelight)
if you have a faulty bulb fitted, it's possible that it is backfeeding power into the sidelight circuit - which will make the rear bulb light up.
(its a bit like when a bad earth makes all the rear lights flash with the indicators)
If it was mine I'd try the original drl bulbs as a help to diagnosis
Thanks for the help guys, I don't know what made me think the rear lights were on all the time. I will try the original bulbs back in the drl and see what happens  in these dark mornings all the bulbs are working correctly so I will have to change them next weekend now. Cheers guys
normally issues like that are caused by the wrong bulb or the bulb incorrectly fitted
  Rear light power problem phlyer 1 2,347 21:st-Dec-2023, 08:27:49
  Abs light and service esp warning 1 week before MOT [emoji24] Sc0tty05 5 9,448 24:th-Nov-2020, 18:25:28
  Dpf regen led light Kiel0777 0 3,213 28:th-Jun-2020, 07:49:45
Last Post: Kiel0777
  Corner light make sistem93 2 4,545 17:th-Dec-2019, 19:39:49
Last Post: sistem93
  Rear Fuse Box leeso 3 3,870 15:th-Nov-2019, 08:19:15
Last Post: tcmtuning
  Eco button light flashing jw021979 6 7,725 9:th-Aug-2019, 21:09:48
Last Post: jw021979
  ESC and Engine Light Acond 2 4,295 16:th-Nov-2018, 19:32:48
  Service power steering warning light. R4hulb 4 13,458 23:rd-Mar-2018, 13:01:58
Last Post: R4hulb
  Boot gate light GTC13LFP 1 3,114 16:th-Nov-2017, 21:26:22
Last Post: Iaintruten
  Rear 12v aux Pg73 4 4,517 27:th-Jul-2017, 09:55:07
Last Post: Pg73
James_McNeil (7:th-Feb-2024, 15:43:24)
