Don't leave ur shopping on the hob and go out
car started then cut out after a few seconds
So yesterday on my run to the Port I had to relieve myself so Stopped at the services went in and used to toilet.
Came back started the car no problems at all it ran for 2-3 seconds then cut out only message to pop up was to press clutch to start.
Tried a few time and nothing every time I turned the key all the lights went out on the dash in the end I had to take the key out and then it was all ok.
Anybody any ideas or had it happen to them?
Heated Seats Pin Out's & Schematics
fuel filter, too much diesel came out
I filled the car up with diesel and drove to my friends house to do the oil change. After that we attempted the fuel filter by turning the drain screw. However, the diesel just kept on coming out and at just over 2 litres was lost we tightened it back up in the hope some knows why it didn't stop?
I was of the understanding that just the fuel out of the filter housing would come out.
Can anyone please help?
Door out of alignment
Hey guys! [SMILING FACE WITH SMILING EYES]
Just have a question about an issue I noticed a few weeks ago before I went on holiday. I've noticed that the passenger side door no longer sits flush with the body of the car (photos attached). I can push the door and it then sirs flush but as soon as I let go it pulls away from the car again.
Any ideas what could have caused this and how I can fix if?!
[IMG]http://images.tapatalk-cdn.com/15/09/03/757d0fc7ea4c1834ecb76c9528540ccf.jpg[/IM
mrtc - Replies:
Is it possible to add a pull out cycle carrier
Is it possible to fit a pull out cycle carrier. Never seen one before not sure if its just non UK market but it would[attachment=592][attachment=593] be cool
Radom hold up on a day out.
So the wife's friend has come back to uk from Dubi so we are off to see them in Swindon.
On the way (On the A31) we got held up by rubberneckers getting a good look at the coach.
[attachment=616]
So I'm sure others get fed up with rubberneckers and could get some good pics of what it was all over.
Check out Chris Knott's new Top 20 clubs
Well, the figures can't lie - as promised here's the Chris Knott Top 20 car club forum rankings for the first half of 2016.
As you know, Chris Knott Insurance specialises in looking after the insurance needs of car enthusiasts, working to help the members of around 200 car clubs/forums across the UK.
To feature in our Top 20, a club/forum will be producing a high number of quote enquiries and we're converting a strong percentage into policies. [b]It hints at the makes and models we'
Lsmcdti - Replies:
HELP astra j 1.7 cutting out
I have an astra j 60 plate 1.7 cdti, a few weeks ago it cut out and when i started it back up it would judder and cut out again, anyway aa bloke only found an egr code, it started and drove fine again so went home, i removed the egr which was not that dirty, cleaned and replaced and has been fine for approx 800 miles but on the way to work today it happened again, massive loss of power then cut off when i started it back up it cut out again, then started again and idled slighly rough but when pr
Lsmcdti - Replies:
I have an astra j 60 plate 1.7 cdti a few weeks ago it cut out and when i started it back up it would judder and cut out again, anyway aa bloke only found an egr code, it started and drove fine again so went home, i removed the egr which was not that dirty, cleaned and replaced and has been fine for approx 800 miles but on the way to work today it happened again, massive loss of power then cut off when i started it back up it cut out again, then started again and idled slighly rough but when i P
