to led light reverse how
How-to led reverse light
THIS IS A HOW TO AND REVIEW OF THE SMD LED REVERSE LIGHT BULB
FOR THE ASTRA J 5 DOOR.
So here are the SMD LED Bulb
that is a Direct Replacement for the Standard Bulb
it looks very well made and it is also Really Bright
and also Error Free.
STEP ONE.
Remove the Plastic Cover from the Tailgate
to gain Access to one Screw and Remove it
then Remove the Two Plastic Caps
and Remove Two more screws
be Careful not to Brake the Rubber Grommets on the Screws.
STEP TWO.
Remove the Light Unit from the car
and undo the Connector from the unit.
Now that you have the Unit out
turn the Unit over and Push the White Tab
and lift the White Holder out
Remove the Old Bulb
and Fit the New SMD LED into Position
then Refit the Unit and the Job is Done.
Here are the Results Day and Night.
This is a Super Bright SMD LED bulb
and the Standard Bulb looks real naff in Comparison with this
the Bulb is also Error Free
so no Problems at all with the Canbus
i can Highly Recommend this LED it looks fantastic
They can be Picked up on ebay, H21W, LED.
here is an Example Link but shop about
http://www.ebay.co.uk/itm/141191988703?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
How much are these then and what bulb type are they?
You don't need a reversing light, just use your super bright No. plate lights!
with both the LED number plate lights and the LED reverse light they do make seeing whats behind you possible for the first time ever
Cameron Riza will have the prices as this is a new product he is now selling
This is the reverse led I've got in the VXR
http://pages.ebay.com/link/?nav=item.vie...4&altz=web
Here's a daytime pic no nighttime pic at the mo
I'm really impressed with the look well worth the price
looks good mate
also if you want to do the rear fog and reverse lights i found these
on ebay http://www.ebay.co.uk/itm/141191988703?_...EBIDX%3AIT
both fog and reverse lights are not on the cambus monitoring so you wont have any problems.
Cheers m8
Ok, tried to fit led reverse light. I managed to broke 2 clips and glued one of them back
fitted led light
and the result!!!!!!!
Didnt bother to take any other photos, I immediately fitted back the old yellowish bulb
Where did you get the bulb?
It could be a faulty bulb.
(24:th-Oct-2015, 19:04:21)Rusty2009 Wrote: Where did you get the bulb?
ebay. Bulb was ok. I thought reverse light wasnt on the canbus monitoring anyway
no i did not as my car was not on canbus
may be a bad bulb there try lush lighting
These bulbs have loads in them and that could be faulty.
I don't get any error up using the LED bulb.
Hmm, I ll try another set then
the set from lush will work for sure
tell him we sent you
Ok, thanks
Do you guys think that the link for the LED's that are in the first post are still good to this?
As I'm from Portugal if they aren't the return would be a little expensive...
They sell two LED's for the price, but they say in the description that in some cars the system will not detect the lamp anyway and that we have to buy a resistor... What do you think?
(18:th-May-2016, 02:25:48)Doraemon02 Wrote: Do you guys think that the link for the LED's that are in the first post are still good to this?
Did you do it? And did it work?
Hmmm
Reading this thread and watching the photos, I got one idea.
As all cars in my country are RHD reverse light is placed on right side of trunk lid.
On UK cars its on opposite side.
So if I get an UK reversing light and put it on my astra I will get two reversing lights right?
But will they both work?
I can find some UK astra here on scrapyard
Sent from my LG G6 using Tapatalk
I don't think you will have 2 reverse lights. You will have 1 reverse light and 1 white fog light.
@Rusty2009 has a nice how-2 where he converted the reflectors to have red LED strips in them for fogs & added a LHD cluster for dual reverse lights.
Something I hope to repeat next year
Have to run a wire across.
Where are those number plate lights from?
(16:th-Feb-2020, 07:30:14)Kiel0777 Wrote: Where are those number plate lights from?
https://www.ebay.co.uk/itm/18-LED-Number...SwJYVdw5yh
  how too AMBIENT LIGHT AROUND THE GEAR GATOR tucpal 165 95,011 15:th-Oct-2020, 06:59:05
  How-to Extra boot light Rusty2009 65 40,775 7:th-Jan-2019, 08:41:31
  security light tucpal 34 22,348 2:nd-Jan-2019, 18:50:28
Last Post: Collster
  How To remove the front courtesy light Rusty2009 6 12,000 16:th-Feb-2015, 01:35:07
cpeter53 (10:th-Oct-2023, 05:45:10)
