Trade Count:
0)
Threads: 1
Thanks Received:
0 in 0 posts
Thanks Given: 0
0
Car: Astra gtc
Sex: Male
Total Feedback: 0
Hi hope someone van help when i put my car into reverse the reverse bulb dont go on anymore checked the bulb but thats nog the problem also checked switch on gearbox thats ok to only thing left is the fuse but cant find location off it in the manual
Trade Count:
4)
Threads: 359
Thanks Received:
4 in 4 posts
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
It's fuse 19 in glove-box, but irrc that also controls other lights.
If It's not the fuse I would try cleaning the contacts on the bulb and holder.
If that doesn't work it could be a broken wire an bad earth point or even the BCM failing to send the signal.
The ground point for that is located behind the trim in the rear on passenger side drop the flap down you should be able to find it.
Trade Count:
0)
Threads: 1
Thanks Received:
0 in 0 posts
Thanks Given: 0
0
Car: Astra gtc
Sex: Male
Total Feedback: 0
Hello thx for your answer hope not the bcm will look at everything andere post if its fixt or nog thx
