ecm issue? recall upgrade causing quot performance
ECM "Upgrade" Recall Causing Performance Issue?
I had my 2013 Astra 2.0cdti in for service last week and was told it had a recall to "upgrade the cars software". I've since learned this is an upgrade to the ECM software.
Since the service it simply does not feel like the same car. I'm having to change down gears to get up hills I've driven everyday without the need previously for example.
Does anyone know what is involved in this upgrade and if it could have altered my car's performance? I believe the upgrade may have something to do with emissions.
If not the only other thing that happened is the paperwork showed my car had actually received the 2012 1.7 service. The dealer said this is not an issue as the service (the 4th) is the same for both. Is this correct?
Thank you very much in advance for any advice/information given.
I noticed the same after they did a ECU update a few months ago.
I found my 2.0 cdti to be more "laggy" after it had a software update back in June
Did either of you get it resolved?
Once an update has been applied it can't be undone.
I wasn't happy as I told them before driving the car the update wouldn't fix the turbo.
  DRL - sidelamp issue stajerad 1 4,165 12:th-Sep-2021, 15:37:54
  Cd400 to nav500 upgrade. tucpal 266 421,359 31:st-Aug-2021, 19:57:38
  DRL/Sidelight Issue MassiveRoy 1 3,924 10:th-Feb-2021, 19:57:52
Last Post: Rhun91
  Stereo upgrade options Amazingusername 6 14,195 9:th-Feb-2021, 14:07:41
Last Post: loeb
  2 days and already an issue..... MrCrunchy 6 6,675 18:th-Sep-2020, 18:32:29
Last Post: MrCrunchy
  Astra J GTC 2.0 CDTI A20 DTH Stage 1 Remap - Wayside Performance M222RJF 8 10,935 11:th-Sep-2020, 20:55:21
Last Post: badger64
  Aftermarket android H5754 headunit issue simpledun 1 4,769 4:th-Jun-2020, 09:17:15
  ASTRA J HEADUNIT ISSUE AstraJ_OwnerSK 1 4,411 10:th-Nov-2019, 08:31:13
  Sat Nav issue Slakky 3 5,991 2:nd-Sep-2019, 13:06:06
Last Post: vocky
  Power, performance and looks RVernon 1 4,355 16:th-Jul-2019, 13:45:07
