tucpal - Replies:
recall
so i have a recall today to remove the battery cover as it may block the cooling fan
and to check the cooling fan is not blocked or obstructed
funny as my car has never had the battery cover fitted but i did get one and fit it myself
so looks like i will remove this just to be on the safe side
i will give them a phone about this as i am not going to the dealers just to have them remove a battery cover
but i also know this is not a new recall and has been around for a while now.
Fuel filler recall
Just rang dealers to check if I had any recalls outstanding.
They said I had a few but only said the fuel filler cap.
I messaged a couple of people who work at dealerships to find out more.
They drill a hole put a wax in then a bung to stop rust between the pipe and body.
Daz21 - Replies:
Vauxhall recall
Hi all I just been told by Vauxhall there is a recall do do rust protection around the fuel filler cap.
Hope this helps you out.
ECM "Upgrade" Recall Causing Performance Issue?
I had my 2013 Astra 2.0cdti in for service last week and was told it had a recall to "upgrade the cars software". I've since learned this is an upgrade to the ECM software.
Since the service it simply does not feel like the same car. I'm having to change down gears to get up hills I've driven everyday without the need previously for example.
Does anyone know what is involved in this upgrade and if it could have altered my car's performance? I believe the upgrade may have something
