ECM "Upgrade" Recall Causing Performance Issue?
I had my 2013 Astra 2.0cdti in for service last week and was told it had a recall to "upgrade the cars software". I've since learned this is an upgrade to the ECM software.
Since the service it simply does not feel like the same car. I'm having to change down gears to get up hills I've driven everyday without the need previously for example.
Does anyone know what is involved in this upgrade and if it could have altered my car's performance? I believe the upgrade may have something
2.0cdti ECU update for DPF causing poor fuel & loss of performace
So when my car had Turbo issue's the dealership did a software update to the ECU.
This update is related to the DPF
Quote:It adjusts the parameters for the dpf temperature sensors to improve dpf performance and avoid overloading dpf, eml lights and in worst cases engine stalling.
it's a software weakness that only effects astra j, cascada and zafira tourers up to model year MY13.5. The update will just adjust the software weakness that is present.
At first I didn't notice
