to install lights foot how well
how to install FOOT WELL LIGHTS
#51
IT IS A BIT TRICKY
I realised how to remove fuse box to get a little bit more room, all sorted and installed now
cool mate that is the way to do it dont forget to add some pictures
Will do mate, waiting until it gets dark though
They look purple but they are blue haha!
The following 1 user says Thank You to Tonto for this post:
  • kincop
well done there they look real good
Ooooo I do like those!!! Ha. Bit too much going on though for me...I like to see the highlights from the ambient lighting and those other LEDs sort of drown them out
Nice guide thanks!
Good tut tucpal, I like the way you've wired it up but I was thinking of wiring it up to the headlights so that when they're on, the foot wells come on as well. Is there already a tut on that?
Omg i still need to do this
if you tap into the ambient lighting from the headlight switch then they will do that
(11:th-Oct-2015, 20:45:01)tucpal Wrote: if you tap into the ambient lighting from the headlight switch then they will do that
Any idea which wires they are? And a pic of possible, electrics isn't my forte
just wire it up to the headlight switch like in this how to
but you will be using footwell lights instead
http://www.vxoc.org.uk/forum/Thread-how-...GEAR-GATOR
Thanks again tucpal
To add rear footwell lights can I just run an extra wire from front footwell lights to the rear? Also is there a particular spot to place them that's best?
(20:th-Oct-2015, 23:33:09)Tonto Wrote: To add rear footwell lights can I just run an extra wire from front footwell lights to the rear? Also is there a particular spot to place them that's best?
I did mine that way mate, I stuck them under the seats in between to vents using Velcro, will grab a pic later.
Excellent thanks mate
Just ordered some of the single strip adhesive backed LEDs that @tucpal recommended for the rear door pockets. Think the big square ones recommended here are too bright for my car. Went for white too to keep up with the red and white interior lights I already have. Can't wait to fit them!
Here's a couple of pics for you @Tonto
Do they look just as good in red? I kinda like the red look opposed to blue
if you have a look in my progress thread your see the red in the front I've not put red under the seats as I was going for a red and blue theme.
http://www.vxoc.org.uk/forum/Thread-Prog...-Rusty2009
Cheers @Rusty2009 I've ordered red so will wire them up when they get here!
They really are very good LED,S and the price is well worth it you will love them
Given that I'm considering wiring these up so that they're on with the headlights, will they be too bright at night?
No not really mate. I still don't recommend having them on all the time they get very hot.
I'm forever having to put new 3m tape on the passenger footwell light and that's after having the door open for 5mins.
Also I would recommend you replace the wire for a thicker wire.
Hmm I might consider some strips in that case then. Less bright and won't get as hot, and like you said, I can replace the wires in the strip.
I've got a reel of strip just not got round to swapping them over.
I was looking at the reels, can they be cut and rewired? It looks cheaper than buying them already cut and wired
Now you mention the reel of strip @Rusty2009 ha, could have said before I ordered 4 new panels haha
Yes most can be cut every 3 LED's.
This is the company I buy from (linked to blue) http://www.ebay.co.uk/itm/5M-Blue-Waterp...SwEppURfoo
I always buy the waterproof ones too.
(24:th-Oct-2015, 10:19:41)Tonto Wrote: Now you mention the reel of strip @Rusty2009 ha, could have said before I ordered 4 new panels haha
Led panels are better under the front seats.
Ah right cool. I bought panels for rear too :/
Cheers Rusty, I've actually been looking at the RGB ones, with a controller to change the colour
I have been looking at them too not sure if they are cuttable just read the description.
Ah well I've ordered some from China, pre cut and pre wired, I'll probably just need to extend the wires. Will let you know when I've done it and I'll grab some pics too
Just a side question, where did you run the wires to the back ones? Through the centre console or along the sides of the the car?
Pics are a must.
I did run them via the centre console but when I took the seats and centre console out to fit the amp I ran them under the carpet.
Cheers rusty, they're not coming until the beginning of November! Snail mail at its finest there
Sooooo I failed at life with this today! Hahaha. I took everything out (glove box etc.) which is now starting to take its toll on the car as I've broke more than 1 clip on every god damn panel in that side of the car! And then could juist barely see the looms I needed to splice into...it was securely tucked behind the fuse box and didn't wanna budge! I don't wanna yank on it and break something and then the sun went down and I gave up :(
Tap off the courtesy light so much quicker and easier.
Oh dear mate, yeah it was a pin but fuse box does come out which makes it easier!
Yeah I was gonna go off the courtesy light but then I'd have to rewire my LED strip as I've already wired and soldered it up now ready for the short trip it would have needed from under the glove box and to the footwell. Will try this weekend anyway
If you can get fuse box out then it is so much easier to get in to! It definitely comes out of holder as mine did! I was upside down in footwell with feet on headrest though haha!
there is a tab each side at the top push them in pull forward then lift bottom out.
The following 1 user says Thank You to Rusty2009 for this post:
  • kincop
Thanks @Rusty2009 I couldn't remember how to get it out off the top of my head.
(24:th-Oct-2015, 12:06:10)Nemo Wrote: Cheers rusty, they're not coming until the beginning of November! Snail mail at its finest there
nemo clear your pm box its full
but they were sold is the answer
I'm not impressed at all with the red footwell lights I've received...
They're very hard to see, I know it's daytime but my blue LEDs were very visible and looked great, these well I can't hardly notice them at all...
See they'd be perfect for me, I want them on all the time at night.
I've got some on order from China that let me change the colour with a remote
They do look dull are they the 48SMD panels?
Yeah I've waited a couple of weeks from Hong Kong too.
Yeah exact same place I bought blue ones, they are 48 smd panels..
http://www.ebay.co.uk/ulk/itm/231237289762
  How to ambient door lights tucpal 214 210,463 28:th-Mar-2021, 00:48:32
Last Post: Benk91
  Super Bright Boot Lights sheppy1 26 28,628 12:th-Nov-2020, 17:54:59
Last Post: Arkanggel10
  How to fit courtesy lights in mirrors kyle-astra-j 21 26,089 18:th-Feb-2018, 06:15:13
Last Post: Leigh0274
  Upgrading Fog lights on J 5 door GarethMyers14 4 11,845 17:th-Nov-2017, 02:25:38
Last Post: sanj424
  How to Puddle Lights Rusty2009 22 34,228 6:th-Nov-2017, 20:16:44
Last Post: zzattack
  HOW TO LED TAIL LIGHTS tucpal 31 35,314 24:th-Oct-2017, 12:29:02
Last Post: Grimo72
  how to upgrade interior lights to SMD LED tucpal 91 84,792 2:nd-Aug-2016, 13:42:21
5 User(s) read this thread:
milozic (24:th-Jan-2026, 20:40:43), obsidian (10:th-Nov-2025, 21:53:25), Buashei (4:th-Feb-2026, 12:23:13), Happy25 (14:th-Aug-2025, 18:59:44), kincop (3:rd-Aug-2025, 19:53:26)
Users browsing this thread: 6 Guest(s)
