How to Install aftermarket head unit
tucpal - Replies:
how to install FOOT WELL LIGHTS
Summit - Replies:
How to Install a Reverse Camera in an Astra J with Navi 900
Here is an installation guide for fitting a reverse camera to an Astra J with Navi 900. If you have the DVD 800, the installation is similar but you will probably need a
RGB interface box instead of the
GVIF interface used in the Navi 900. I presume Navi 600 is the same as Navi 900 as far as reverse camera's go but I cant be sure abou
Install GPS Tracker for less than £30
[align=center][Image:
I have installed a GPS tracker, available from Amazon for around £26-£29 delivered. Go to Amazon and search for GPS tracker. You will see one listed as GPS car tracker with GPRS and vehicle theft protection system (model TK103A).
You will need a 'Smart phone' so you can see your car's location when you use the tracker. I use an Android phone but works on Iphones too.
Link: [url=http://www.amaz
How to install Sat Nav to a safe location
This little gadget seems too obvious for me to post it online and technically it isn't a 'how to' guide. However, I'm sure there are drivers on this forum who may just have overlooked this idea so I'm posting it in case it helps someone.
Instead of having your TomTom stuck on the windscreen in your face, there is a 'gooseneck' available, some made my TomTom themselves and others that are after market. Mine is an after market one and may do the job better because as far as I know it is slightl
So this thread will be used for me to gather info and then add it to this original post...rather than having info all over various threads etc.
I want to start off by linking to the module I'm personally installing:
http://www.iceboxauto.com/vauxhall-opel-...id-44-m072
There are two other main models I'm aware of which are the C072 and A1884 (think that's the model number) which have varying difference
How to Install Android Head Unit + Wireless Reverse Camera
Welcome to my tutorial on installing the Android M072 Aftermarket Head Unit (this tutorial could probably be used for other head units too) and wireless reverse camera. So here’s a pic of everything I ordered and needed for this mod:
Head Unit Itself:
So you’ll want to follow the tutorial that @rusy2009 put up on how to remove the head unit:
[url=https://www.vxoc.org.uk/forum/Thread-How-to-remove-the-head-unit-from-the-car-includes-Screen-removal]https://www.vxoc.org.uk/forum/Thr
Wanting to install bluetooth and upgrade CD400
As per the title
Next stage of upgrades to my car
As I have previously mentioned I was pretty hacked off that my Sri didnt come as standard with bluetooth (go figure that my wifes 63 plate £9K Kia has it!)
I dont want to undertake the work myself as I have very little patience and even less ability !
Been pricing up for bluetooth only install, metavoice system, circa £249 plus £100 fitting
This strikes me as pretty expensive for just having bluetooth
For an extra couple of hun
Tablet install.....
Hey all
Has anyone done a diy tablet install please as im interested into doing it myself?
thanks in advances
james
Sub Install
Recently got a 1.7 CDTi (12 plate, it's my first car!) and just installed a new Android 7.1.2 Head unit from icebox - all good so far apart from AUX and USB not working (no connection provided that will work with factory USB, Rob looking into it for me)
Just a couple of questions, apologies if they are answered somewhere!
Has anyone installed a Sub & Amp and if so, how did you route the wiring?
Also, to anyone who has purchased a DAB module, where did you locate the aerial
