removal steering wheel airbag
Steering wheel airbag removal
Has anyone removed the the airbag / horn from the steering wheel?
Had a look on the workshop manual and it says to make a tool to unhook it form the back.
I know to disconnect the battery and wait at least 30 minutes.
Its reall easy to do. Invert the steering wheel by 180. You will find it easier the steering wheel towards you. On the rear there are 2 holes with a slot next to them. I used a thin screwdriver in each hole then move them towards outwards to unclip the airbag. Takes about 30 secs to remove. I'll sort some pics later.
Thanks mate
Just edited my post
[Image: 20140617_090504_zpsqbbfge7z.jpg]
Here you go mate use a screw driver in each hole and move it outwards to unclip. I did one side at a time and eased the airbag forward to disengage it from the clip
Thanks mate, I'll have a look later.
  Steering wheel angle, esp, power Steering smoky-jr 3 6,141 6:th-Jun-2021, 18:23:26
Last Post: jeniferbitcoin71
  Easy removal of glowplugs? Euroshopper 1 4,870 13:th-Nov-2020, 16:21:11
Last Post: eatmybogbrush
  Broken wheel stud Euroshopper 1 3,152 6:th-Oct-2020, 07:08:18
  Steering wheel from Astra K foxydimsi 2 5,947 1:st-Oct-2020, 06:49:56
  GTC limited edition alloy wheel paint code Nathan191210 5 6,184 1:st-Aug-2020, 19:22:43
  2017 GTC Limited edition - Front wheel noise Nathan191210 4 5,451 12:th-Jul-2020, 07:37:10
  space saver wheel Gary13 5 6,247 24:th-May-2020, 19:02:57
Last Post: Gary13
  Squeak when turning steering wheel Rusty2009 12 23,361 12:th-Sep-2019, 21:45:35
Last Post: Boycey1969
  Lowering and wheel spacers twinpipes 1 3,859 28:th-Jul-2019, 08:43:33
  Astra VXR heated steering wheel THEHITMAN 26 24,821 10:th-Mar-2019, 09:34:44
no_name (2:nd-Feb-2025, 01:02:05)
