electronic working handbrake not
Electronic handbrake not working
Hello
My handbrake is not working, the braking cable gets tight and compresses the lever on the brake caliper but nothing happens. (This tells me that there is nothing wrong with the electronic handbrake but rather the brake caliper itself) This is on both wheels. The lever I am talking about is pictured below. My brake pads are in need of a change but they have quite a few miles left in them and this should not happen.
To me it seems like the brake caliper lever gets depressed to the maximum amount and nothing happens. The handbrake first malfunctioned on one wheel, but it is now on two wheels.
Have some one experienced this before? Do I need to change both rare brake calipers?
Kind regards
Can you move the lever by hand, possible you have seized calipers
(28:th-Jul-2021, 19:06:38)Jpbroad1970 Wrote: Can you move the lever by hand, possible you have seized calipers
Yes, I can move them by hand. Is your best guess to change both rare brake calipers? Normal breaking is fine though
I am guessing you are probably right, because I almost never use my electronic handbrake and the car is parked outside.
It sounds that way to me, have you had it off the floor and tried to manually apply handbrake via caliper just to see if it grips disc. obviously won't be as tight as cable but should feel a change.
  Deadlock not working Jonika21 5 5,307 22:nd-Dec-2020, 17:37:08
Last Post: Jonika21
  Electric passenger window not working Harposaurus 2 6,080 30:th-Sep-2020, 19:29:35
Last Post: Harposaurus
  Sat nav unit, from insignia? Not fully working? Macauleyh96 10 10,406 18:th-Aug-2020, 14:40:41
Last Post: DNT
  service parking assist and tpms not working kevinmcken1404 3 6,501 18:th-May-2020, 10:09:32
  Cruise control not working raimon 10 30,539 27:th-Nov-2017, 12:33:46
Last Post: AlanMac
  change handbrake Dale90 1 4,505 2:nd-Aug-2017, 08:20:19
  handbrake Dale90 2 9,377 29:th-Jun-2017, 11:57:26
Last Post: Dale90
  Astra gtc wiper and start stop not working Robbjp 5 10,163 24:th-Sep-2016, 21:09:32
Last Post: J1ODYA
  vxr electronic hand brake releases on own !! when started ChrisL 7 10,630 20:th-Jan-2016, 21:07:49
Last Post: Steve64
