vxr electronic hand brake releases on own !! when started
My car is a month old now but 4 times now started car & the bloody things rolled of on its own,has anyone else had this problem or am I a total idiot, It's got one of those horrible button handbrakes if you can call it that ! According to the dealer they cant fault it.
Anyone on here had this problem.
Thanks Chris
"Electronic Stability Control System" & flashing "Malfunction indicator light"
When driving last night i got the "electronic stability control & traction system" symbol when is staying constant.
Today it appeared again AND a flashing "malfunction indicator light" also appeared. The cars power was restricted.
Its a 2012 1.4 petrol. The car is misfiring a small bit.
Can anyone advise the problem?
Electronic handbrake not working
Hello
My handbrake is not working, the braking cable gets tight and compresses the lever on the brake caliper but nothing happens. (This tells me that there is nothing wrong with the electronic handbrake but rather the brake caliper itself) This is on both wheels. The lever I am talking about is pictured below. My brake pads are in need of a change but they have quite a few miles left in them and this should not happen.
To me it seems like the brake caliper lever gets depressed to the maxi
