releases electronic started hand vxr brake own when on
vxr electronic hand brake releases on own !! when started
My car is a month old now but 4 times now started car & the bloody things rolled of on its own,has anyone else had this problem or am I a total idiot, It's got one of those horrible button handbrakes if you can call it that ! According to the dealer they cant fault it.
Anyone on here had this problem.
Thanks Chris
Not had that issue with any of epbs I've had the Astra's I have owned. Only thing I have noticed is if you literally just flick the switch it doesn't always work so I tend to just hold it up for a second and it works every time then.
Hi John,
Tried it today if i lift up the clutch & touch the throttle it drops of,i think it assumes i'm in gear about to move of,I don't think i touched the throttle the last few times it's done this,As to putting it on i have noticed like you it has to be held for a few seconds before it shows it's on in the dash display.
Chris
you are pulling it up two times and not just once
two pulls gives you full handbrake when parked
(18:th-Jan-2016, 20:09:08)tucpal Wrote: you are pulling it up two times and not just once
I never knew this lol my cars never rolled off
I'm on my 3rd Astra with EPB snd never had any issues.
Your right though if you lift the clutch and touch the throttle this will allow the EPB to release.
I've never pressed it twice haha. It always had its light on the dash after one pull
I think when the clutch is depressed and the accelerator pedal is slightly pressed and you are on an incline the epb will come off , thinking you are doing a hill start.
Try doing the same without being on an incline and it won't release the brake .
  Electronic handbrake not working Euroshopper 3 4,183 29:th-Jul-2021, 15:21:44
  Brake pedal sensor learn. Richiew1986 0 2,886 22:nd-Jul-2021, 16:53:31
Last Post: Richiew1986
  Gtc 2017 1.4t 120 front brake disc size Nathan191210 2 7,955 25:th-Apr-2020, 07:41:05
  Rear brake pads and discs everson38 4 6,739 28:th-May-2019, 10:53:57
  Jolt when releasing brake on autobox Djones55 3 7,173 21:st-Oct-2018, 10:42:34
Last Post: Canasta
  Brake bleed nipples? Jake 4 8,524 27:th-Apr-2018, 18:36:07
Last Post: Jake
  Rear brake disc size Daniel199025 0 5,055 17:th-Sep-2017, 22:15:55
Last Post: Daniel199025
  Wheel Noise Following New Brake Pads & Discs GJH1985 5 8,972 24:th-Jul-2017, 10:12:34
Last Post: GJH1985
  Astra Electric parking brake BZone1 16 40,255 21:st-Dec-2016, 08:59:09
  High Level Brake Light? steve7 15 29,822 16:th-Dec-2016, 01:26:08
Last Post: irishastraowner
