over heated no engine oil
Engine over heated no oil
Engine over heated on motorway stopped checked water okay then checked oil no oil in the engine topped up to max restarted engine knocking top end left it till the next day started it up when cooled down and it was smoking for 10 mins and ruff idle smoke cleared up and still knocking and ruff idle rev it past 2000 rpm and it sounds normal any ideas got the turbo in the specialist today to found out if the turbo are fault thanks????
Vauxhall Astra 2.0 cdti 165bhp
2011 97,000 miles FSH
a lack of oil can cause many problems inside an engine, get it looked at by a garage or engine specialists
Took it the garage this morning they reckon it's a fuel problem I will keep you updated [Image: 14c90a2bf9c7b33baf6a4f4301797318.jpg][Image: 05d7887752d84c19d1077d564913afcb.jpg]
Sounds like the injectors but no oil is not good at all
New turbo in tucpal [Image: b4736e3d366bf60e8c6bf246a009610b.jpg][Image: 861cec2069b76c6bdd3699895708170f.jpg]
Big job not good have a big job done myself it is not good when they go wrong that's for sure
I had to split the turbo to put it in night mare to get the oil pipe on the 2 10mm bolts and the 3 on the exhaust manifold
  Engine oil level low ,Add oil Rocky33 0 3,371 14:th-Apr-2021, 12:56:53
Last Post: Rocky33
  Intermittent low loss of engine power Mark72 2 8,903 28:th-Dec-2019, 13:59:37
Last Post: Mark72
  Cold engine idle Lee 4 13,511 15:th-Aug-2018, 19:09:17
Last Post: Lee
  Astra J 1.7 81kw engine power guitz 1 14,732 8:th-Jul-2018, 10:39:46
  URGENT HELP PLEASE: Distressed Engine Squeel/Groan Vx-Mad-G 13 30,079 30:th-Jan-2018, 15:55:51
Last Post: Vx-Mad-G
  Engine swap help joshparker1911 1 10,972 24:th-Jan-2018, 17:37:59
Last Post: vocky
  Fumes straight from engine bay Raf7007 2 10,954 21:st-Sep-2017, 23:57:16
Last Post: Simon Templar
  Engine chugging under acceleration ellis0896 3 10,465 20:th-Jan-2017, 18:02:53
Last Post: Astra VXD
  a17dte engine noisy? rbull51 3 7,628 22:nd-Jul-2016, 19:26:54
  Engine compression 1.3 DTE sotoskon 5 11,842 29:th-Mar-2015, 17:13:12
