under chugging engine acceleration
Engine chugging under acceleration
I have a 2012 Sri 1.6T, It doesn't happen all the time but regularly enough to bother me. What's happening is when I'm.accelerating the engine is chugging, it's not turning off. no matter what gear I'm in or how hard I'm accelerating it will still happen.
fit some new spark plugs or try a different fuel would be the first things on my list to try
You could stick some fuel system treatment in your fuel tank and possibly look into changing your fuel filter if it hasn't been changed in a while.
Change your coil pack! Very cheap. Then see if it still does it. I drove my grandads 1.4 Astra and it was juddering on acceleration I suggested to him the coil pack or spark plugs need changing. Took it to vx and turned out to be coil pack. The emission light also came up on the dash
  Engine oil level low ,Add oil Rocky33 0 3,533 14:th-Apr-2021, 12:56:53
Last Post: Rocky33
  Intermittent low loss of engine power Mark72 2 9,304 28:th-Dec-2019, 13:59:37
Last Post: Mark72
  Cold engine idle Lee 4 13,916 15:th-Aug-2018, 19:09:17
Last Post: Lee
  Astra J 1.7 81kw engine power guitz 1 15,001 8:th-Jul-2018, 10:39:46
  URGENT HELP PLEASE: Distressed Engine Squeel/Groan Vx-Mad-G 13 30,692 30:th-Jan-2018, 15:55:51
Last Post: Vx-Mad-G
  Engine swap help joshparker1911 1 11,107 24:th-Jan-2018, 17:37:59
Last Post: vocky
  Fumes straight from engine bay Raf7007 2 11,133 21:st-Sep-2017, 23:57:16
Last Post: Simon Templar
  Engine over heated no oil kyle-astra-j 6 10,708 1:st-Jun-2017, 11:22:20
Last Post: kyle-astra-j
  a17dte engine noisy? rbull51 3 7,865 22:nd-Jul-2016, 19:26:54
  Engine compression 1.3 DTE sotoskon 5 12,150 29:th-Mar-2015, 17:13:12
