| Welcome, Guest |
| Forum Statistics |
» Members: 12,338
» Latest member: Griff81
» Forum threads: 4,563
» Forum posts: 49,693
| Latest Threads |
Astra J 2014. Electric st...
8:th-Sep-2025, 21:22:49
| front brake discs |
Posted by: bgb65uk - 22:nd-Jul-2020, 12:22:14 - Forum: Mechanical
- Replies (4)
could anyone tell me what size discs i need for the front of a 2014 gtc 1.4 t,i ordered a pair from a reputable supplier just to find they where too small ,, advice please
| Navi 950 retrofit to Buick Encore |
Posted by: vibalt - 20:th-Jul-2020, 23:37:44 - Forum: Retrofit Research
- Replies (3)
Hello everybody,
I installed the navi 950 in the Buick encore, reprogrammed the EEPROM with the Buick encore VIN and everything went great (head unit works fine). After leaving the car locked for a while and turning on the head unit again, there is no sound at all even turning signals or open door sounds dissapear.
Can anyone help to solve this problem?
| Newbie |
Posted by: Nubby - 19:th-Jul-2020, 13:11:24 - Forum: Introduction Area
- Replies (1)
Hi, I'm Dave, I have a 2014 astra J turbo. Looking for general advise and support as I will be doing all mechanical work myself. Thanks in advance
| 1.6 cdti 5 door exhaust tip? |
Posted by: h4r7y - 16:th-Jul-2020, 15:44:23 - Forum: Astra-J/GTC
- Replies (1)
I wonder if anyone else has wanted a visible exhaust tip for their 1.6cdti 5 door? On the 2.0 cdti you can see the exhaust under the rear bumpers valance, does anyone know if its easy to swap over from the 2 litre car? Or could i just buy the bumper insert and a backbox after that? (Im led to believe theres little point in getting anything performance related for a diesel exhaust?)
Thanks in advance!
| Bluetooth/Dab retrofit Navi950? |
Posted by: Bsouthby - 16:th-Jul-2020, 15:23:04 - Forum: Astra-J/GTC Howto's
- Replies (5)
Hello,
I have recently bought my Astra J After having an Astra K As my company car (Couldnt quite afford the K :()
Its a 65 plate Astra Tourer 1.6 cdti
It came with a cd400 and an after market bluetooth thing which is okay but doesnt give me any options on the radio itself. So I dont know whos calling with looking at my phone or dont know what music is playing so its kinda pointless.
I've done alot of searching on google and on here about retofitting and upgrading to different radios. Ive done this before with my 58 plate astra with tech-2 but now it looks a bit different.
What I really want to know are my options
I want bluetooth dab and satnav does the J have an apple car play radio like the K? That's what I have in my company car and if I could have anything like that I'll be happy preferably oem and not after market.
Also maybe something that can do parking sensors or reverse camera as this car is massive and doesn't have anything to help me whilst reversing.
Many thanks,
Ben
| Lurker to member! |
Posted by: h4r7y - 10:th-Jul-2020, 11:41:44 - Forum: Introduction Area
- Replies (1)
Ive been lurking unregistered for a little while now, not had my car all that long. Looks like a great resource so thanks for having me!
| P0193 Code Help |
Posted by: yessi - 10:th-Jul-2020, 08:49:54 - Forum: Electrical
- Replies (3)
Good Morning All,
This has been documented in my thread a while back but hopefully more people will see this here and provide help.
https://www.vxoc.org.uk/forum/Thread-yes...ra-J-Elite
I've got a recurring issue and I've already changed a number of things however the issue persists.
When I start the car, randomly, the car sometimes will start to crank, stop and then continue and eventually start. When this happens however it enters some sort of limp mode and advises 'Service Vehicle Soon'. So to confirm, the car struggled to start but started first time, out of the drive, no power. Struggles to rev past 2k and over 15mph is a push but not EML light on.
The quickest way to resolve this I have found is to clear the fault codes and the car starts fine next time around.
Plugging my OBD and Delphi in I get the P0193 error it states Fuel Rail Pressure Sensor Circuit, high voltage. I've already changed the fuel rail sensor for a brand new part and the issue still persists.
What on earth could be causing this?
I've already done the following:
- Changes Glow Plug Cyl 3, my car has the stop start so really expensive to change all of them.
- Changed Fuel Rail High Pressure Sensor
- Removed, cleaned and tested EGR Valve. Cleaned first time around when this happened, we had it off and tested the mechanism off the battery, the EGR opened and closed without issue.
| GTC limited edition alloy wheel paint code |
Posted by: Nathan191210 - 9:th-Jul-2020, 23:35:25 - Forum: Astra-J/GTC
- Replies (5)
Ive refurbed alloys in the past using a dremel, varying git sandpaper, filler, primer, paint and clear coats. Generally it has turned out well.
I plan to try to do the same to my GTC limited edition alloys soon. Originally I thought they where diamond cut due to the coloring and texture, but at closer inspection and a bit of sanding I believe them to be painted.
Example wheels
https://images.clickdealer.co.uk/vehicle...810321.jpg
Can anyone confirm that they are painted? or am I completely wrong. Im looking for the correct paint code for the lighter outer sliver.
