» Members: 12,318
» Latest member: Josephcic
» Forum threads: 4,568
» Forum posts: 49,721
From $50 to $5,700: The B...
Forum: Vauxhall General
Last Post: Jonathaneuk
Yesterday, 04:07:48
» Replies: 5
Binance Mining Paid Me $9...
Last Post: conyas92
19:th-Feb-2026, 19:25:28
» Replies: 5
  Headunit advice needed
Posted by: shabba - 11:th-Nov-2017, 21:23:25 - Forum: ICE - Replies (12)
I havent got a clue when it comes to changing/ purchasing the correct headunit for my car.
Ideally im looking for bluetooth (dont have presently) a unit with a usb port built in as my car doesnt have one of those either. Satnav and it has to have Android.
I have looked around the forms but its all double dutch to me.
I wouldnt even attempt to install this, so anybody recommend anywhere in the North East of England or North Yorkshire.
Looking at £500 including fitting?
My car is a 2014 model.
Would i be able to fit a Navi650 or Navi950 without difficulty?
  drl light flicker.
Posted by: THOMAS123 - 10:th-Nov-2017, 09:56:30 - Forum: Lighting - Replies (2)
recently replaced my drl light with leds and main beam with halogens from hids direct.ive noticed that when i use the start/stop on my gtc the drls flicker for a second when i activate the engine again.anybody got ant ideas why this happens.bulbs are in tight could it be a faulty ballast.
  Auto lights stuck on main beam?
Posted by: umognog - 9:th-Nov-2017, 17:46:04 - Forum: Lighting - Replies (3)
Alright folks,
After changjng the LED colours in the headlight switch, I've found out main beam is always on.
I need to take it out again and make sure the switch is properly seated of course, but just wanted to check if there were any additional recommendations simultaneously.
  timing belt and water pump
Posted by: bigsadie - 9:th-Nov-2017, 16:21:59 - Forum: Mechanical - Replies (5)
Hi all. I just want to ask when i should change my timing belt and water pump? I have a gtc 2l cdti with 56000 miles. When do i need to change. Im not sure if it has ever been done as their is no record. Only had car 8 months. Any advice appreciated. I dont want to wait incSe my engine gets ruined. Thanks for your help. Regards
  Engine Revs High
Posted by: MoosaM - 9:th-Nov-2017, 15:40:54 - Forum: Astra-J/GTC - Replies (1)
Hi Folks,
I have a 2011 Astra 2.0 SRI (Diesel) 42k on the clock.
I have noticed (although its very intermittent; 3 over the last 6 months) that when I have set off from traffic lights and change up from 1st to 2nd; I lose power and the revs increase as if I have depressed the clutch and accelerator at the same time. I have had to pull the car over switch it off and start again and all is back to normal.
It drives perfectly fine otherwise, no loss of power or anything.
any ideas?
thanks in advance
  Abbreviations
Posted by: Rusty2009 - 9:th-Nov-2017, 10:31:37 - Forum: Site help - Replies (4)
A member asked if a post for abbreviations could be made so please see below.
I'll add them over time, if there is anything you would like added to the list reply & I will add it into the main list.
Car abbreviations
BCM = Body control module
ECU = Engine control module
CIM = Column Integrated Module
2WD = Two Wheel Drive
4WD = Four Wheel Drive or 4X4
AWD = All Wheel Drive
FWD = Front Wheel Drive
RWD = Rear Wheel Drive
ABS = Anti-Lock Braking System
AFS = Adaptive Front-light System
AFL = Adaptive forward lighting
CVT = Continuously variable Transmission
EBA = Electronic Brake Assist
EBD = Electronic Brakeforce Distribution
ESC = Electronic Stability Control
TCS = Traction control system
PAS = Power Assisted Steering
PHEV = Plug-in Hybrid Electric Vehicle
SUV = Sports Utility Vehicle
AC = Air Conditioning
ACC = Adaptive Cruise Control
EGR = Exhaust Gas Recirculation
EPS = Electric power steering
ISOFIX = Isofix is a standard anchoring system for child seats in cars
RDS = Radio data system
DAB = Digital Audio Broadcasting
TPMS = Tyre pressure monitoring system
DPF = Diesel Particulate Filter
NOx = nitrogen oxide
CO2 = Carbon dioxide
Vauxhall computer / programming abbreviations
GDS2 = Global diagnostic system
SPS = Service Programming System
VCI = Vehicle Control Indexing
General abbreviations
TBH = To be honest
IMHO = In my honest opinion
RTFM = Read The Flipping Manual (or the F word that rhymes with ducking)
WTF = What The Flip (rhymes with Duck)
OEM = Original Equipment Manufacturer
Thanks @Big Dave2 & @Jerry for their input.
  FLEXRIDE COILOVERS
Posted by: Dangerepox - 8:th-Nov-2017, 22:19:58 - Forum: Astra-J/GTC - Replies (2)
Hello.
Its possible to put coilovers on Astra GTC J whit Flexride and reset advice on Dashboard?
  Meriva B 1.7 A17DTS (130) Weird Starting thing
Posted by: TubaMagna8 - 8:th-Nov-2017, 16:18:42 - Forum: Small cars Agila, Merivia, Viva, Adam & Corsa - Replies (4)
Car is the Meriva B 1.7CDTI the 130bhp model, been faultless pretty much, had a new battery a few months ago, Anyway its been coming up with the service vehicle soon message every now and again, but i gather that is for fault codes to be read? it doesn't show up all the time...
Anyway this morning i was out taking pictures somewhere, had driven there engine had been up to temperature and that before i arrived. Put the key in the Ignition had the radio on for 5 mins went to start and it started then died.... did this about 6 times, started straightaway every time, took the key out put it back in and it started and was fine... been fine since, Just wondering if its a warning of something? I looked about and some mention of the EGR valve stuck open maybe?
Grateful for any help.
Best wishes
Jonathan
  AUX Ground Loop problem! Can anyone help?
Posted by: bagnallman - 7:th-Nov-2017, 20:49:11 - Forum: Electrical - Replies (4)
I'm an owner of a 2013 Astra GTC with a slight issue when using the AUX cable for my music.
I have white noise/crackling when plugging into the AUX socket, which I believe is a ground loop isolation problem after some research online. That would mean that there is an earthing/grounding problem somewhere amongst the car's electricals.
Purchasing a ground loop isolator to plug into may be one option - but I was wondering if anyone knew the cause of the issue? Or has had the problem themselves and managed to locate the culprit?
As finding the issue and cleaning/fixing the earth would be my preferred resolution
All the best
  2013 astra Bi-turbo
Posted by: jj120979 - 6:th-Nov-2017, 11:56:49 - Forum: What's it worth - Replies (1)
Hi all due to changes in our company car policy looks like i will have to part with my astra.
after some help with pricing the car,,
2013 astra hatch Bi-turbo.(Red)
77k, full service history
Navi 600,Bluetooth, rear camera, folding mirrors, electric rear windows, cruise control, anti collision alert, xenon's,auto wipers/auto headlights/dimming mirror,hill hold,electric hand break.
will be really gutted to give the car up..
thanks james
