problem can aux ground help? anyone loop
AUX Ground Loop problem! Can anyone help?
I'm an owner of a 2013 Astra GTC with a slight issue when using the AUX cable for my music.
I have white noise/crackling when plugging into the AUX socket, which I believe is a ground loop isolation problem after some research online. That would mean that there is an earthing/grounding problem somewhere amongst the car's electricals.
Purchasing a ground loop isolator to plug into may be one option - but I was wondering if anyone knew the cause of the issue? Or has had the problem themselves and managed to locate the culprit?
As finding the issue and cleaning/fixing the earth would be my preferred resolution
All the best
Can I ask what radio system you have fitted?
as the aux is wired different across the range.
Sorry for late reply.
It is a cd400.
For those who may be suffering a similar problem. I have tried cheaper eBay alternatives but they are of poorer quality.
This cable seems to of solved my issue:
https://www.studiospares.com/Cables-Lead...590660.htm
However, this is just disguising the problem and any ideas to a permanent fix would be appreciated. Thank you
I'll grab you the wiring info later.
Thank you
  Rear light power problem phlyer 1 5,043 21:st-Dec-2023, 08:27:49
  Meriva B GID problem edomali 0 4,924 28:th-Apr-2021, 11:47:03
Last Post: edomali
  CD400 power problem bigles 6 7,876 22:nd-Dec-2020, 05:56:33
Last Post: bigles
  IPC upgrade problem coabacje 0 5,512 11:th-Jan-2020, 18:58:54
Last Post: coabacje
  Problem reverse light Keith2017 6 18,132 1:st-Apr-2017, 17:55:16
Last Post: Keith2017
