sheppy1 - Replies:
Additional AUX socket
Does anyone know if it's possible to install an extra AUX socket in the car? I'd like to have one in the glove box so I can connected up a Bluetooth dongle in there and have my phone auto connect to it like suggested in another thread.
sheppy1 - Replies:
AUX Cable Connector
Does anyone have any photos of the AUX cable connector...I'm talking about the end that connects into wherever it goes behind the head unit.
neilll - Replies:
CD400 Aux issues (MP3)
Does anybody know why my USB/AUX port would not work?
I first tried plugging in a small USB hard drive (always worked with my old head units) and now I've tried a 16gb SanDisk Cruzer Force (just with 4 MP3 albums on it) and it always says something like 'no aux devices detected'
It's a CD400 head unit and the car is only 1 year old......and its super annoying
Rich-72 - Replies:
Aux/bluetooth upgrade?
Just bought a 2011 Astra elite but it doesn't have Bluetooth or an aux input. Is this something that can be fitted? And if so how much will it roughly cost?
Thanks in advance.
Rear Lighter/Aux Power Plug
I have the Genuine vauxhall (meriva) Rear aux power socket but it ideally requires the three pin plug as used on the tyre compressor, is anyone breaking a car that has the loom with the plug?
Just want a bit of it so i can put an aux socket in the boot.
Pg73 - Replies:
Rear 12v aux
Hello, I've got a 2012 se and want to fit a rear 12 v aux socket, I've had a look in the boot and there is a fuse box on the N/S how easy is it to wire one to this, I'm useless with electrics so nice and easy please?
AUX Ground Loop problem! Can anyone help?
I'm an owner of a 2013 Astra GTC with a slight issue when using the AUX cable for my music.
I have white noise/crackling when plugging into the AUX socket, which I believe is a ground loop isolation problem after some research online. That would mean that there is an earthing/grounding problem somewhere amongst the car's electricals.
Purchasing a ground loop isolator to plug into may be one option - but I was wondering if anyone knew the cause of the issue? Or has had the problem the
Aux device not detected
Good morning, new user here.
I have a 2012 GTC wich has an irritating problem with the 3.5mm aux input. Searching the interwebs I have not found anyone with the same issue, yet alone a solution so thought I would sign up and ask the question.
Using the 3.5mm aux input there is often a delay in it detecting that anything has been connected, sometimes it works straight away, but rarely.
More often, what happens is that once I connect a a device and start playing music through it I am gre
tzr608 - Replies:
navi 600 memory card usb aux wiring
Hi everyone .....if i upgrade from the navi 500 to the 600/900 what and how do i wire up for the memory card connection please
Mr_Benn - Replies:
Centre console Aux in question
[attachment=1072][attachment=1073]Hi all,
I hope someone here has seen this before because I have been through the owners manual and googled quite a bit with no luck.
I have a 2010 Astra (J) SRI.
Next to the cig lighter to the right I have the 3.5mm Aux in socket.
On the opposite side (where the USB would be if included) there is another socket (see pics) and I have no idea what it's for.
Looking in there with a torch it looks like it has metal contacts for power of some kind.
