AUX Ground Loop problem! Can anyone help?
I'm an owner of a 2013 Astra GTC with a slight issue when using the AUX cable for my music.
I have white noise/crackling when plugging into the AUX socket, which I believe is a ground loop isolation problem after some research online. That would mean that thereĀ is an earthing/grounding problem somewhere amongst the car's electricals.
Purchasing a ground loop isolator to plug into may be one option - but I was wondering if anyone knew the cause of the issue? Or has had the problem the
