revs high engine
Engine Revs High
Hi Folks,
I have a 2011 Astra 2.0 SRI (Diesel) 42k on the clock.
I have noticed (although its very intermittent; 3 over the last 6 months) that when I have set off from traffic lights and change up from 1st to 2nd; I lose power and the revs increase as if I have depressed the clutch and accelerator at the same time. I have had to pull the car over switch it off and start again and all is back to normal.
It drives perfectly fine otherwise, no loss of power or anything.
any ideas?
thanks in advance
Hi there, sounds as if your clutch is on its road out to be honest, don't be surprised as mines needing done at 49000 as I got my car remapped but has toasted the clutch lol.
  1.4T Engine noise Nathan191210 1 3,915 29:th-Jun-2021, 09:05:07
Last Post: jay2801
  Please advise - Z16LET engine (1.6 turbo, 132 kW) - is it a direct or indirect port? UseThe4s 2 8,398 18:th-Apr-2021, 09:58:47
Last Post: UseThe4s
  "Stop Vehicle Immediately Engine Has Overheated" Advice appreciated please Dennis S 25 55,680 30:th-Aug-2020, 13:56:18
Last Post: Rgotts00
  1.6 cdti engine reliability Loddy Jeff 7 21,352 9:th-Jul-2020, 22:04:47
Last Post: Loddy Jeff
Spanner Light illuminated with engine off Wwood1991 2 5,974 11:th-Feb-2020, 13:01:57
  High Idle 1.7 cdti Cossie 0 4,503 26:th-Aug-2019, 07:06:32
Last Post: Cossie
  New Engine Needed ? Breengin 19 15,665 14:th-Mar-2019, 08:48:57
  Squeek/Rattle when starting engine Wabe_IV 4 6,794 7:th-Feb-2019, 12:15:33
  Noise when turning engine off Marc_81 6 9,677 30:th-Jan-2019, 20:46:28
Last Post: Marc_81
  Engine Oil. THOMAS123 2 5,065 7:th-Oct-2018, 21:43:14
Last Post: THOMAS123
