High mount brake lamp
JohnL - Replies:
High Beam Assist and LED street lights
Does anyone else's car struggle to detect that there are LED street lights so sticks main beam on?
They have recently replaced all the local street lights to the LED style which is great but now if I have High Beam Assist switched on the car thinks there are no street lights so it puts high beam on.
steve7 - Replies:
High Level Brake Light?
My boot has water where the spare wheel is and I've now figured out, it's coming through the High Level Brake Light in the Centre, has anyone removed this ok without chipping the glass? the 2 bolt's behind it are welded can't figure out how to remove the glass break light? Thanks
High beam rear view mirror
Selling my HighBeam auto dimming rear-view mirror part number 13369365, will also come with the mirror covers.
One of the covers has had one of the little grills cut (this was for my dash cam) but it's not really noticeable.
I'm looking for £120 posted paid as gift, the mirror alone costs £400+ from VX.
[Image:
http://i124.photobucket.com/albums/p39/r...C_0907.jpg ]
[img]http://i124.photobucket.com/albums/p39/rustywhite2007/high%20beam%20auto
VK91 - Replies:
Third break light/High level break light
Hi, my third brake light has gone out, also known as the high level brake light on my 5 door Astra J (2012).
I have read the forum and the following link,
https://www.vxoc.org.uk/forum/Thread-Hig...rake+light . But there isn't a walk-through on how to actually remove this. I've googled it and know where can I find a walk-through on how to do this this looks really difficult as mentioned by people on here and other forums. I would really appreciate it if someone
High Level Brake Problem
Anyone else had problems with the high level brake light mine seem to have stopped working? Any ideas how to try and solve it or is it a new light unit?
Requesting High pressure fuel Pump part number
I have a 2012 Vauxhall Astra MK VI (J) 2.0 CDTI SRI which i bought over a year ago and after owning it 3 months the High pressure diesel pump leaked and had to be replaced which i was fortunate with as it was under warranty. Fast forward to now, i have the car in for a service and it is now leaking AGAIN which i will have to pay out of my own pocket this time.
[color=#ffffff][font=Helvetica, Arial, sans-serif]i found this listi
MoosaM - Replies:
Engine Revs High
Hi Folks,
I have a 2011 Astra 2.0 SRI (Diesel) 42k on the clock.
I have noticed (although its very intermittent; 3 over the last 6 months) that when I have set off from traffic lights and change up from 1st to 2nd; I lose power and the revs increase as if I have depressed the clutch and accelerator at the same time. I have had to pull the car over switch it off and start again and all is back to normal.
[color=#000000]
Turbo vane position sensors voltage high
Does anyone know anything about this do you think I’ll have to change the sensors or is there away to fix it or things to check thanks in advance
Auto dim High beam assist mirror
