off turning noise engine when
Noise when turning engine off
Over the past couple of days I've noticed a horrible noise when turning my ignition off. It only lasts for a second our 2 but it's almost like a grinding noise.. sounds like it's coming from the drivers side of the engine bay but I could be wrong. Car is a 2.0 cdti.
Could be water pump, are you losing any coolant?
Decided to try the garage I bought it from as I've only had the car 10 weeks.. they've looked at it and reckon it's the AC Compressor... gonna do it as a gesture of good will even though they said it's a wear and tear part so I'm happy about that. Is this normal on a car that's done 38k miles?
Glad they are sorting it.
"Is this normal?" define normal as there is no such thing, every component is different and have weakness etc so while you would like to think it should last x amount of years or miles it may not. You don't know if the last owner had the aircon on all the time they drove the car, or if they never had it on.
So 3 weeks on and the garage are fobbing me off with this... they never get in touch and I struggle to get them. Spoke to them this morning and they are saying there are 2 variants of the part so they've not been able to order it (took them 3 weeks to tell me this!)... so.. I need the part number but don't know where to look. Can anyone help identify where the AC Compressor is on a 2.0 CDTI?
Marc
PM me your reg and look up the part number.
Sorry I completely forgot to reply to you. Thanks for the offer but I ended up ringing a local dealership who gave me the part no. (Yes... only 1!). The garage begrudgingly through gritted teeth did the repair at the weekend so all sorted now.
  1.4T Engine noise Nathan191210 1 3,910 29:th-Jun-2021, 09:05:07
Last Post: jay2801
  Please advise - Z16LET engine (1.6 turbo, 132 kW) - is it a direct or indirect port? UseThe4s 2 8,375 18:th-Apr-2021, 09:58:47
Last Post: UseThe4s
  "Stop Vehicle Immediately Engine Has Overheated" Advice appreciated please Dennis S 25 55,604 30:th-Aug-2020, 13:56:18
Last Post: Rgotts00
  2017 GTC Limited edition - Front wheel noise Nathan191210 4 6,603 12:th-Jul-2020, 07:37:10
  1.6 cdti engine reliability Loddy Jeff 7 21,262 9:th-Jul-2020, 22:04:47
Last Post: Loddy Jeff
Spanner Light illuminated with engine off Wwood1991 2 5,970 11:th-Feb-2020, 13:01:57
  Squeak when turning steering wheel Rusty2009 12 25,505 12:th-Sep-2019, 21:45:35
Last Post: Boycey1969
  New Engine Needed ? Breengin 19 15,572 14:th-Mar-2019, 08:48:57
  Squeek/Rattle when starting engine Wabe_IV 4 6,746 7:th-Feb-2019, 12:15:33
Grinding rotating noise from GTC? MattDe123 2 6,405 1:st-Nov-2018, 10:30:33
Last Post: MattDe123
