rotating gtc? grinding noise from
Grinding rotating noise from GTC?
Got a little problem with the GTC 2014 Sport CDTI 2.0L. Recently its been making this horrible grinding noise. The noise is really loud when I turn the car on in the morning, it eases away when the car is warmed up a bit but does not disappear. It seems to be coming from under the engine but I can't be sure.
A lot of information online has pointed to the DMF or clutch release bearing, not sure which applies to me.
The noise is made when;
- The car is turnt on, gear in neutral, clutch decompressed
- First gear, second gear and can even hear it slightly in higher up gears
- When the clutch is disengaged
When I push down the clutch, the noise seems to go and returns when I put it into gear and release the clutch.
I've attached a short video (turn up volume)
Look forward to your replies, any info would be useful
Thanks, Matt
that sounds very much like the dual mass failing
(31:st-Oct-2018, 19:44:37)johno1412 Wrote: that sounds very much like the dual mass failing
Yeah i thought so too
  1.4T Engine noise Nathan191210 1 3,713 29:th-Jun-2021, 09:05:07
Last Post: jay2801
  2017 GTC Limited edition - Front wheel noise Nathan191210 4 6,245 12:th-Jul-2020, 07:37:10
  Noise when turning engine off Marc_81 6 9,141 30:th-Jan-2019, 20:46:28
Last Post: Marc_81
  Clicking noise THOMAS123 1 4,701 16:th-May-2018, 08:06:00
Last Post: rlievens
  Squeaking, whirring and grinding mw2299 2 6,807 11:th-Oct-2017, 06:41:07
Last Post: Straws
  Clutch adjustment/grinding gears dammfust 1 5,258 22:nd-Sep-2017, 00:03:22
Last Post: mw2299
  Engine noise Lukedent1234 3 5,605 21:st-Sep-2017, 10:56:53
Last Post: Rob6606
  Ticking Noise eddier1558 10 27,862 7:th-Sep-2017, 18:25:53
Last Post: eddier1558
  Wheel Noise Following New Brake Pads & Discs GJH1985 5 8,988 24:th-Jul-2017, 10:12:34
Last Post: GJH1985
  Intermittent engine rattle noise Weeman424 1 5,798 21:st-May-2017, 22:07:02
