midge - Replies:
grinding / scraping noise
Hi all I've been advised by Russel to post on here I have the 1.7 cdti 2011 and I've been getting a grinding /scraping noise coming from the front of the car sometimes it sounds like its coming from the wheel area or even the engine bay ... It don't happen when the car is idle only when driving and the sound increases when I accelerate ... I've recently changed the front break disks and pads but that didn't solve it ... The noise doesn't start immediately when driving useualy about 2-3 mins of d
rbull51 - Replies:
Dry, almost grinding type noise from front wheels / discs area
I have noticed a strange noise on my astra j. The noise sounds like when a brake disc lip may be slightly rubbing / touching the caliper. However, it is not this making the noise. The noise happens all the time. It doesnt change if i brake, turn left or right and it doesnt change with clutch or gear changes. If i push the car when it is off i can still hear it. Possibly from drive shaft area?? Has anyone else had this?
Clutch adjustment/grinding gears
I've recently bought a 1.4t astra J. To me the clutch bite is way too low. I find myself trying to get through gears rapidly and grinding gears, especially 1st into 2nd. With the nature of the engine, it needs to be reved, but I find myself nervous of moving through the gears too much.
It may well be me, and the way I drive, but the clutch bites and disengages within the bottom inch of travel. Is this normal? Can it be adjusted at all?
Thanks,
Ben
mw2299 - Replies:
Squeaking, whirring and grinding
I've had my J since mid-August. Haven't really had any issues until now. It's a 1.3 CDTI. I noticed a squeaking that was getting louder. I looked under the bonnet and it was one of the belts (not sure which) but it didn't quieten/get louder with acceleration. The squeaking has now died down and now I mainly hear a whirring from inside the car, as if the belt is struggling to go round. Just earlier on a short journey I heard three times, what I can only describe as a grinding sound, the same soun
Grinding rotating noise from GTC?
Got a little problem with the GTC 2014 Sport CDTI 2.0L. Recently its been making this horrible grinding noise. The noise is really loud when I turn the car on in the morning, it eases away when the car is warmed up a bit but does not disappear. It seems to be coming from under the engine but I can't be sure.
A lot of information online has pointed to the DMF or clutch release bearing, not sure which applies to me.
The noise is made when;
- The car is turnt on, gear in neutra
