JohnL - Replies:
Drivers Heated seat turning off
Had this on my Elite it ended up having the pad replaced. When switched on they would work for about 2 minutes and then turn off. However if you put them on a lower heat setting they would stay on longer.
Anyway the VXR has started this morning. Heated seat works for 30 seconds no matter which heat setting you have it on. I've seen some people mention that there is a bulletin regarding the wiring loom when they have had the same issue. Does anyone know if this the case or not?
webby. - Replies:
Occasional problem turning on
I have this problem, very rarely, where when I turn on the car, the engine doesnt seem to bite correctly.
It tries to go but then just seems to tick over a few times it eventually does start but sounds likes its not going to for a few seconds.
Like i say its very rare it happens, and all i can narrow it down to it not turning the key enough, Im not expecing many replies as i know its an awful description but thought I'd just put it out there.
Astra is a 1.6 petrol energy
Squeak when turning steering wheel
Squeak when turning steering wheel, getting really annoying now anybody else got it?
Marc_81 - Replies:
Noise when turning engine off
Over the past couple of days I've noticed a horrible noise when turning my ignition off. It only lasts for a second our 2 but it's almost like a grinding noise.. sounds like it's coming from the drivers side of the engine bay but I could be wrong. Car is a 2.0 cdti.
Leady78 - Replies:
Side turning/indicator wiring diagram to help install sequential LED DRL strip.
Hello all,
I am planning to fit/install front sequential LED light strip which has the function of DRL & indicator signals. I need help or advise on how best to do this. Is it best to try and tap into the side panel indicator or the lower front indicator that is next to the fog light?
Any help would be appreciated, I have experience in wiring other lights on the car but this is the first time I have looked at fitting a sequential LED light strip that needs to use the indicators as a addit
