Do you want a off topic area
Do you want an off topic area so you can chat about anything?
If so just list what you want below and I'll sort it.
Sri logo off front arch
If anyone has or is planning to debadge their car, please let me know if you have a spare badge. I'm painting them black and putting them on the inside of my car, need 1 more. Will pay postage and any costs, thanks
JohnL - Replies:
Drivers Heated seat turning off
Had this on my Elite it ended up having the pad replaced. When switched on they would work for about 2 minutes and then turn off. However if you put them on a lower heat setting they would stay on longer.
Anyway the VXR has started this morning. Heated seat works for 30 seconds no matter which heat setting you have it on. I've seen some people mention that there is a bulletin regarding the wiring loom when they have had the same issue. Does anyone know if this the case or not?
Bumper needs to come off
So when fitting my new drls from lush lighting city, I've dropped an old bulb into the lighT!! Then I got a plastic stick and put blutack on it then dropped that in the light!!!!! Is there anyway to get the light out without taking the bumper off?? Or just gettin the stuff out??
Not going to fit the load resistors just yet as the car is going to the garage for warranty work so don't want them to be questioning it.
Off to get a quote
Off down to a hydro dipping place to get a quote on my engine cover, fuse box cover and air filter, will let you know the prices
Bumper lacquer coming off
tucpal - Replies:
one off find
Was very close to be write off
Well coming back from work after night shift and this happens
[Image:
http://tapatalk.imageshack.com/v2/14/11/...950edb.jpg ]
Once i hit it i lost all drive, like it was stuck in the last gear which was 5th.
Told me vechile needs service.
Then told me engine overhearing - gone to idle mode.
The rad and cooling fan has been push and bent like ****
NOT HAPPY, specially as im still paying the ****er off.
Astra write off....?
Hi everyone, I crashed my car a few weeks ago and wrecked the passenger suspension ( hit a kerb). When parked at a garage a man tried squeezing thru and scraped my wing and I've went thru his insurance. I've been called to the garage (vauxhall) and they've told me my car has been in an accident prior due to crash bar being bent and a couple of other things.. They don't know I hit a kerb and the chassis is bent.. An assessor is coming out to see the car next week, is there any possibility they'd
INFORMATION OFF YOU!!!
Is there any kits about to fit front driving lights next to the indicators Thanks again for all your help in previous items I have sorted wheels nuts and pedal covers CHEERS
