slow to idle hanging revs
hi all question for you all has anyone had an issue with the revs hanging around 1200 -1500 rpm then slowly dropping to idle on 2.0 cdti sri
everything  else seems ok i only have a code reader which i shall be putting on tomorrow to see if anything pops up but at a wild guess im thinking throttle body gunked up causing it to stiffen up
[color=#efefef]i only had the car 3 months it has 60k on the clock says full service history but as i havent d
Engine Revs High
Hi Folks,
I have a 2011 Astra 2.0 SRI (Diesel) 42k on the clock.
I have noticed (although its very intermittent; 3 over the last 6 months) that when I have set off from traffic lights and change up from 1st to 2nd; I lose power and the revs increase as if I have depressed the clutch and accelerator at the same time. I have had to pull the car over switch it off and start again and all is back to normal.
[color=#000000]
