problem with assist park
Problem with park assist
So recently i have noticed when i press the park assist button it no longer displays on dash "park assist on" but if i turn it off it will say the off...
Anyone any idea how to solve this please?
We today have had battery off for other things today and that hasnt reset issue.
no idea a trip to the dealers for you
lol bugger
Lewis before turning the key in take it out of gear, as the system is checking everything.
Even thou you shouldn't leave a diesel in gear.
My park assist only gives a off message never had a on message the default is on with ignition
I never get park assit on message but it comes up with a pic of the car and little boxes in front and behind.
If it works when you park it must be on
Rusty2009 Wrote:Lewis before turning the key in take it out of gear, as the system is checking everything.
out of curiosity why should you never leave a deisel in gear? mine is diesel and i do constantly
I do to when im parked on drive :-)
Gilmore Wrote:out of curiosity why should you never leave a deisel in gear? mine is diesel and i do constantly
Yeh I do, reverse if I'm facing down hill, 1st if I'm facing up? Can it cause problems
A diesel can start even without the key in the ignition.
Rusty2009 Wrote:A diesel can start even without the key in the ignition.
I think that's true on the older engines. I think with the newer ones are controlled more by the ECU rather than mechanical pumps
Maybe but I wouldn't take the risk, I would rather turn the wheel to point to the kerb when parked on hill at least if the Handbrake failed the kerb will stop it rolling away
Very true
See I do talk sense sometimes Lol
  ongoing problem UPDATE Cameron UK 35 39,370 23:rd-Aug-2021, 11:00:32
  My new Gtc problem already DE5IRED 18 22,947 28:th-Feb-2020, 23:58:11
Last Post: Zaf312
  Astra j radio / display problem Trublu24 6 24,813 1:st-Feb-2019, 08:38:04
  MAF Mass Air Flow Sensor is this common problem caretaker 3 18,157 21:st-Aug-2016, 19:42:18
  Service Park assist Kris 8 17,131 13:th-Jan-2016, 19:23:35
Last Post: Kris
  fan blow problem ozzysastra 7 13,539 31:st-Dec-2014, 09:52:28
Last Post: Lewis6317
  Occasional problem turning on webby. 3 15,121 17:th-Oct-2014, 18:50:27
  Hill active assist Lewis6317 15 19,718 9:th-Sep-2014, 10:42:48
  got quite a problem Gilmore 8 22,942 23:rd-Aug-2014, 10:40:08
Last Post: Gilmore
  Brake Assist Warning Light duncboyd 8 22,825 19:th-Aug-2014, 07:52:40
