assist active hill
Hill active assist
Does anyone know how i can see if this os working?
I used to get a message on my dash when parking on my drive that is on but now i don't
I've never had a message come up but know it works
You wouldnt as its only on astra with an electric parking break :-)
Mine doesn't bring up a message
Hill start assist doesn't require the car go to have EPB
Hill Start Assist
The hill start assist allows the driver to launch his vehicle without a roll back while he is moving his foot from the brake pedal to the*accelerator*pedal. The EBCM calculates the brake pressure, which is needed to hold the vehicle on an incline and locks that pressure for a certain time by commanding the appropriate*solenoid*valves ON and OFF when the brake pedal is released. Hill start assist is activated when the EBCM determines that the driver wishes to move his vehicle up-hill, either backwards or forwards.
The following inputs are used for hill start assist feature:
•*Brake switch
•*Brake pressure
•*Longitudinal acceleration
•*Engine torque
•*Reverse gear information
•*Clutch switch
•*Accelerator*pedal position
•*Vehicle speed
my car brings the message up every time i apply the EPB on any slope
park on a hill apply the EPB then release the brake then the hill start should hold you
for a few moments as you pull off
the message should appear as you apply the brake
Thanks guys i will give it a try, as its going vx tomorrow want to make sure it deffo not working. As carshop will not be paying the bill
Find a step hill to test it on, As said Sunday I find to get mine to work I have to Push the pedal down hard.
No its defo not working :-/
If its not working shouldn't i get an maintenance light up?
Never had a light on either the Elite or the VXR to say that Hill assist was active. But saying that reading the manual your meant to have a light to tell you Auto wipers are active etc. I think it's just down to it you have the on board computer or not.
There is nothing more on HSA other than what Corinshtaz has posted I had a quick look on the net and all I'm getting is HSA is only for vehicles with EPB (Which is complete rubbish as I have a manual hand brake and I have HSA).
John I noticed that too about auto wipers and also DRL's I asked the dealership (I take what they say with a pinch of salt) but they said I won't have the lights on the dash as I have the message popup in the IPC.
My wifes 13 plate Mokka has HSA with manual H/brake and that comes up with a message
The brother in laws Astra has HSA with a manual handbrake.
Rusty my Elite did have the light to say the DRL's were active but nothing for the other features.
It's annoying hopefully once I got the xenon's I might get some new lights on the dash
The drl light would be nice to have on the dash... Ok i think i rebook it for next month when i get it serviced ....
  Service Park assist Kris 8 17,076 13:th-Jan-2016, 19:23:35
Last Post: Kris
  Problem with park assist Lewis6317 14 21,245 22:nd-Aug-2014, 17:42:19
  Brake Assist Warning Light duncboyd 8 22,767 19:th-Aug-2014, 07:52:40
