door gtc passenger won open astra t
Passenger Door won't open - Astra GTC
Hey Guys,
So recently noticed an issue. On my 62 plate 1.7 Astra GTC.
When I unlock the car and open and try to get into the passenger side door, the door won't open no matter how much I pull on it?
Any ideas
Thanks?
Sent from my moto g(8) plus using Tapatalk
Stupid question, have you tried pressing open button twice.
Did it work before?
(16:th-Jun-2021, 18:37:01)Jpbroad1970 Wrote: Stupid question, have you tried pressing open button twice.
Did it work before?
Yeah so I've been through some scenarios.
1) To Unlock the car, you need to go inside, pull on the handle once to pop up the door lock knob and then pull the handle a 2nd time and the door opens.
2) When you press the lock button once it locks the driver's door fine,but the second lock does nothing to the passengers, you can Hear the lock trying, but it does nothing to engage the locking latch
3) The only way to lock the car is to manually push the door knob down as you pull on the handle.
4) Pressing the unlock or lock button coutlntless times on fob offers nothing to lock or unlock the passenger door.
5) If you manually unlock the door from the inside, and then close the door, then lock the car fully with the fob, you can open the door and it sets of alarm
Sounds like to me the n/s door lock has packed up or wiring issue, sometimes get broken wires where door hinges but then you wouldn't really hear the motor trying.
Don't know if it show as fault code on diagnosis
(17:th-Jun-2021, 10:09:05)Jpbroad1970 Wrote: Sounds like to me the n/s door lock has packed up or wiring issue, sometimes get broken wires where door hinges but then you wouldn't really hear the motor trying.
Thanks for this, looks like an inspection first job and go from there, just wanted to see if it was a very common thing that all of them have and simple fix of a fuse
Strip down and check is what I would do
First thing I would do is go into the menu via the stereo and change the unlock settings to one click of the remote to see if that makes any difference.
  Astra J Total power loss Galway11 2 6,242 15:th-Dec-2020, 16:37:26
Last Post: Galway11
  Astra J Power Sounder dawks 4 8,735 20:th-Nov-2019, 18:27:56
  Astra J 1.7cdti - oilk catch can milika 0 5,522 2:nd-May-2019, 23:27:18
Last Post: milika
  Astra J 1.7CDTi - Boost sensor location for Chipbox jason.dexter 8 15,233 4:th-Feb-2019, 14:40:25
Last Post: rlievens
  Convert non power fold door mirrors Telsun 2 7,878 1:st-Jan-2019, 09:09:58
  A14net Astra sedan oil gear Gili056 3 6,820 22:nd-Oct-2018, 06:09:34
Last Post: crisse_fin
  Opel Astra J interior fan problem hejhopp123 3 10,610 21:st-Oct-2018, 21:35:28
  Astra J 1.7 CDTI Tech-Line rear light cluster issue AstraCDTI 1 8,981 29:th-Aug-2018, 07:27:16
  Re-map astra j 2.0 cdti ecoflex kyle-astra-j 8 12,605 4:th-Feb-2018, 22:55:44
Last Post: Iaintruten
  Astra J to an Astra K everson38 2 7,185 4:th-Jan-2018, 23:07:55
Last Post: everson38
